65 & 66 common questions and modifications
MattsIASlickShop
Post by MattsIASlickShop »
we will add content to this thread as it pertains to the common modifications we have done to these trucks.
Power steering column swap Instructions:
http://www.fordification.com/steering-column.htm
Power disc brake upgrade page:
http://www.mongrelmotorsports.homestead ... discs.html
MattsIASlickShop
Don't have your hood fly up on you.
Johnny Canuck wrote:Don't have your hood fly up on you.
Drill a hole in your emergency latch (Falcon shown but a slick is very similar).
use a hitch pin or padlock through the hole, and save expensive hood, windshield, and underwear repair :wink:
[albumimg]1117[/albumimg]
greythorn3
Post by greythorn3 »
how common is the hood flying up?
Ray
wheelordie.com my alaska offroad website
Rosati
Post by Rosati »
Not very common. Usually it happens when the latch assembly is misajusted or worn.
I hate Message Boards.
3ontree66
Post by 3ontree66 »
Every one of these I've owned has had the preverbial dent in the middle of the hood from a windshield kiss. Happened to me last week. :roll: :roll:
66 F100 300 4 speed! Power steering!
78 Kawasaki KZ650
75 Yamaha XS 650 x 3.
82 Suzuki GS850G.
64 f100
Post by 64 f100 »
The hood coming loose is a more common problem than should be. Nothing like driving down the road at 70 mph to suddenly have to stick your head out the window so you can find someplace to pull off the road while you shut it down. Scare the hell out of you.and do some seious damage to the cowl and roof.
dav
Post by dav »
had my hood pop up no the "I" doin bout 85 or so not only did the hood get the windshield kiss marks but damaged the cowl as well
God rules ,slicks rock & Mopar motors don't fit well (yet)
fmartin_gila
Post by fmartin_gila »
I installed a positive latched, inside the cab pull type setup on mine. Came from a 77 ? GM pickup. Just had to make a mount for it down in the hole. Works with the stock loop already on the hood. A side benefit is that as long as the doors are locked, they cant get under the hood.
Fred
macgiobuin
Post by macgiobuin »
I installed a hood lock (chain w/lock receiver found on Ebay for about $5) for security. Also will stop the hood from surprising you out on the interstate.
My Baby: 1966 F100
Paranoid!
Post by Paranoid! »
I had a hood on a 1977 stepside fly up on me one early morning on the interstate!
Besides instantly scaring the s@#t out of me!!
Head instantly hit side window!!!Hard!!trying to look out
Coffee everywhere!!
Couldnt see under the dam hood!!!
What a morning...
I thought I was wrong once...
Turned out I was right!!
Russell
craighill74
Post by craighill74 »
Damm I am now truly jealous. I can barley get mine to do over 60 with out complaining LOL
nolabama
Post by nolabama »
power steering sticky is giving a 404 url not found error
"Detroit - leaves those peoples alone, they livin' in Mad Max times" Moe
DV65CustomCab
Post by DV65CustomCab »
As much as I hate to refer people to "that other site", here's an article with photos on converting the repro core support to fit a '66 which would also be similar for a '65.
http://www.ford-trucks.com/forums/1023253-how-to-convert-the-reproduction-core-support-for-66-use.html
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
JOELHEWITT
Re: 65 & 66 common questions and modifications
Post by JOELHEWITT »
I drilled a hole as stated and keep a lock in mine, it's no problem to stick my hand in there to unlock.
Located JUST SOUTH OF ATLANTA GEORGIA C.S.A.
jfm
Post by jfm »
macgiobuin wrote:I installed a hood lock (chain w/lock receiver found on Ebay for about $5) for security. Also will stop the hood from surprising you out on the interstate.
Could you perhaps provide an item number or link? I was not able to find what I thought you described.
jfm
Post by jfm »
craighill74 wrote:Damm I am now truly jealous. I can barley get mine to do over 60 with out complaining LOL
Mine will do 70 to 80 and get 20 mpg. Somebody before me put a 2.75 axle under there. Don't ask it to pull more than itself, though. As far as pulling goes, as an ex-partner liked to say, it wouldn't pull a greased string out of a cat's you-know-what.
Liberty
Post by Liberty »
Is there a photo of where to drill the hole in the emergency latch? Also what keeps the emergency latch from moving?
65 Ford F100 Style side 8' bed 352 V8 4Spd Granny Gears
Liberty
Answer to both questions: depends on the lock! Find a big lock which will not fit through the slot when mounted laterally across the emergency latch, mark and drill a hole low enough for easy access, but not low enough to be easily visible. The latch will be able to move somewhat, but will be unable to dislodge itself from the slot.
DJ Bill
Post by DJ Bill »
Here's the current URL for the power steering into 65-72 trucks...
http://www.fordification.com/tech/powersteering.htm
69supercj
Post by 69supercj »
I just used a small aluminum carabiner instead of a lock to keep the latch from pulling through the hole. Works and is real easy to remove but obviously wont provide security against theft.
