62 unibody build
- twistedfreak
If you post the link when you are logged in it asks us for your password.
Try logging out and then posting a link to the album.
- twistedfreak
lets try this one i made it public so well try it again
http://s63.photobucket.com/albums/h130/ ... rd%20f100/
""WE THE WILLING, LED BY THE UNKNOWING, ARE DOING THE IMPOSSIBLE FOR THE UNGRATEFUL""
- SixtySix Ford
Nice build Twisted!
Question....how do you plan to mount your Manuel rack? Im guessing your going to weld a couple tubes to your front axle then have a slip yoke for the streering rod?
any new updates?
any new updates?
"Nitrous is like hot girl with STD's. You know you wanna hit it, but your afraid of the consequences."
66 Ford F-100 - Project SickUp
- twistedfreak
- twistedfreak
- twistedfreak
well like i said i finally got my air back up and running after the pump went out and now the work is back in gear got most of the passenger side floor back in after i got it cut out and its not started welded in tomorrow it the front half and the moving over to the drivers side also cant wait till my stainless brake and fuel lines get here so i can start on that
- twistedfreak
- twistedfreak
- twistedfreak
- twistedfreak
Nice work! Not sure how you're going to put seatbelts in, but I would've put in shoulder belt attachments on those corners before tacking them inside the cab since you had access to the backsides.
- twistedfreak
- twistedfreak
- twistedfreak
