63 unibody
- Reds Rod Shop
Looking good. I like the bubble top too.
Red
My 1964 Restomod Project http://fordtruk.com/forums/viewtopic.ph ... sc&start=0
dragginwagon
- Reds Rod Shop
Looking good as always man. I look forward to the progress reports on it. Have you done the tank in the frame rails before? I've thought about the same thing but was unsure about the rectangle tubing vs round. We actually built some out of round pipe for a '51 Chevy truck and mounted them down the sides of the frame rails one time. Worked pretty good and didn't take up much space.
Red
dragginwagon
- Reds Rod Shop
No, I don't think you'll have any issues at 150 psi and the 1/4" wall tubing.
Red
- Gary Seymour
dragginwagon
- Reds Rod Shop
Just plain out sick, Are those 22's? They look a lot bigger than my 20's.
Red
dragginwagon
napass2004
fire truck
fire truck
dragginwagon
- Hookedtrout
dragginwagon
got some upper arms from summit to help with lift, im having trouble clearing the fenders
also test fit the motor/ trans. only had to trim about an inch of the lip on the firewall off. stock trans hump bolts back in also! i will have to modify the shifting arm on the c6, its murdering the floor. also not sure what im gunna do about a master cyl/ booster... 460 is freakin huge!!!
