Starter bolt question?
Help! I'm installing a new starter in my '66 with a 352 engine. What is the secret to put in the top bolt that is almost inaccessible due to its location and the exhaust tubing nearby, short of pulling out the engine? When I pulled out the old starter, it was missing both the tab and the bolt. This is nothing like working on my 223 !
1964 F100 Custom Cab Shortbed
Dave Rogers
Re: Starter bolt question?
Not sure if same, I use 14" of extensions from front of motor on my 352. I'm think in of using studs next time.
DAVE
I just did mine. I used a short socket with a three in ext. then I continued to do do 1/8 turns.
Thanks. I will try that. Its just so far back and down its ridiculous.
