Power Windows
WrongBedDave
Power Windows
Post by WrongBedDave »
Used PFM's write-up on the power window conversion using the factory regulators and saturn power windows. Then did a few tweaks of my own to come up with this:
(Click on the pic for the video)
Rotating the factory handle (or vicegrips :hm: ) up or down makes the window go up and down. Still needs some final adjustment but it works!
Dave
Last edited by WrongBedDave on February 19, 2013, 4:48 am, edited 1 time in total.
Dave
63 Wrong Bed 2WD : 302/C4, drip rails shaved, aluminum radiator/e-fan, 16 gallon fuel cell, "custom" gauges, 1000W sound system
Photobucket Album:
http://s1084.photobucket.com/albums/j413/davewave649/
Build Thread:
viewtopic.php?f=32&t=27105
Re: Power Windows
Post by rickairmedic »
Thats Awesome :D yet another idea I'm going to have to um pilfer :D.
WrongBedDave
Re: Power Windows
Haha be my guest, the motor is easy (bolt in almost if you do it Kid's way) Its the crank/switch that gets tricky
Dave
Photobucket Album:
Build Thread:
Rusty 63
Re: Power Windows
Post by Rusty 63 »
I've read PFM's write up -- can you give the link to Kid's?
WrongBedDave
Re: Power Windows
My mistake for some reason I thought it was Kids write up
Dave
Photobucket Album:
Build Thread:
Rusty 63
Re: Power Windows
Post by Rusty 63 »
That's okay - I just thought I missed some good reading.
http://www.purpleflyingmonkey.com/1964- ... indow.html
I've seen where some company sells switches that replace the crank -- how'd you do yours?
WrongBedDave
Re: Power Windows
If you use the Saturn motors there's no room for the crank switch. I found a way to mount a toggle switch and then made an arm attached to the crank trigger it. But to do that the motors have to be moved slightly
Dave
Photobucket Album:
Build Thread:
1965fordf100
Re: Power Windows
Post by 1965fordf100 »
That's sweet Dave! Are you gonna do a write up on that? I was just reading Chris's tech article using the Saturn motor and was thinking i wanted to be able to use something similar to what you just did, then flipped to truck talk and saw your post...a tech article would be sweet!
Phil
WrongBedDave
Re: Power Windows
When I build the driver side I may do a write up but I wanna be able to test it for a month or two to make sure it works perfectly before I do that
Dave
Photobucket Album:
Build Thread:
Re: Power Windows
8) Nice work Dave!, are you going to show the switch set up as well?
WrongBedDave
Re: Power Windows
Heres a video of the internals. Same deal as before, click on the pic
Dave
Photobucket Album:
Build Thread:
PFM-64f100
Re: Power Windows
Post by PFM-64f100 »
Ahhh I see now.. great job. Can't wait for your write up this is a nice feature.. :)
WrongBedDave
Re: Power Windows
Hahah that means ill have to take measurements if i make a write up, all the dimensions on that were either eyeballed or done on the fly. But ill write em down for the driver side when i do it
Dave
Photobucket Album:
Build Thread:
PFM-64f100
Re: Power Windows
WrongBedDave wrote:Hahah that means ill have to take measurements if i make a write up, all the dimensions on that were either eyeballed or done on the fly. But ill write em down for the driver side when i do it
I know I had to do the same thing. Thank you in advance for doing it.
some close up photos of the bracket might also help/work. :) viedo is good but can't zoom like a picture.
WrongBedDave
Re: Power Windows
Haha yeah the video of the internals was for my own future reference so i didnt bother getting a close up. When i go home for spring break ill do the write up. Sorry you guys have to wait a month :roll:
Dave
Photobucket Album:
Build Thread:
1965fordf100
Re: Power Windows
I did some research on those motors and the same motor is used in several GM cars and trucks, including 1500's...they are just about everywhere
Phil
PFM-64f100
Re: Power Windows
1965fordf100 wrote:I did some research on those motors and the same motor is used in several GM cars and trucks, including 1500's...they are just about everywhere
One thing to note. I have also found other motors that are the same but had a differnt gear on them. Something to check when sourcing from other vehicles. I agree they were used in lots of vehicles.
1965fordf100
Re: Power Windows
Good call Chris! All I did was cross reference the part number with other vehicles....are those gears removable?
Phil
WrongBedDave
Re: Power Windows
Good to know. I don't think they are but I didn't try to take the gear off so I'm not sure
Last edited by WrongBedDave on February 23, 2013, 4:26 am, edited 1 time in total.
Dave
Photobucket Album:
Build Thread:
ras4434
Re: Power Windows
Post by ras4434 »
Mine came out of a Cadillac. I took the rear window motors cuz they have less wear..
