65/66 and 67-72 trucks
this is the 61-64 heater
both standard and magic-aire use the same core
this is the 61-64 core
note the flange that mounts the core to the heater
this is the 65/66 heater
again both standard and magic-aire use the same core
65/66 core
the 61/64 and 65/66 cores are the same dimension but the bottom side is different and the 65/66 has no flange
this is a larger version of the 65/66 core
[albumimg]3577[/albumimg]
notice the comparison
regardless of the box info it does not fit the 65/66.it may fit in some of the 71-72 heaters which i think is what i bought it for
this is a 67-72 type heater. it uses the same core as 65/66
here is a comparison of ford truck heater cores,
L-R
9042 large core
65/66 core
2nd generation econoline high output van heater 68-74?
not sure about the one on the right.it is either a 73/79 or one from a factory air conditioned 67-72
if you know speak up!
