3 carb
3 carb
better lucky than good has worked for once. Didn't realize how much there is to know about tri powers. supposed to know this before purchase. I have correct float bowls, metering blocks, carb bodies. Center bowl float level hole is higher than other two. End carb main bodies airhorn are not drilled for choke shaft. End carbs metering blocks have no provision for power valves. Been searching for info for hours. Funny thing is you couldn't make me study in school and yet I spend hours researching car stuff. It also appears that there is no ported vacuum. All the holes and passages are there but one. The base plate is not drilled. Looks like those plugs and fittings aren't doing much.
1963 uni PATINA BLUE
1965 short bed
1965 short bed
- skidoorulz
Re: 3 carb
I know absolutely nothing about Ford tri power but it seems to me that the carbs are on backwards.
Re: 3 carb
I'm assuming that's for a 292
Bowls would be facing the front
That would be correct... Wouldn't it
- jkimbrel65
Re: 3 carb
That's a fe tri-power.Ask away Kenny We'll try to answer your questions.Sen me your mailing address and you can borrow my tri-power book Carbs are correct
Mike
Mike
I tried being normal once...
Re: 3 carb
It's an FE setup.
I fund a similar FE setup with 2x4. Lowriser '63 intake.
Tony Branda is a good source for replacement parts. They have the fuel logs, linkage, etc.
Here is a good source for intake numbers for original Ford intakes (an pulleys, blocks, heads, and about everytihing else Ford).
http://www.mustangtek.com/FordIntake.html
Another good site for replacement parts is:
http://carlsfordparts.com/main.html
Get on the Holley site and you can find most original jet/power valve settings for about any carb. If yours aren't listed, send them an email and they will respond.
Your carbs are on right. You do need the correct float adjusting setups, those aftermarket ones aren't as good and actually can strip float bowl threads.
Good find!
Good find!
- Uncle Skip
Re: 3 carb
Mike is right. We have the answers.
Let me know what you need. I took notes when I did mine.
- Uncle Skip
Re: 3 carb
First, what are the list numbers on the carbs?
Center carb is the only one with a power valve. I can save you a lot of time, money and aggravation on jet sizes too.
Been there, done that.
Re: 3 carb
Its all good. 2436/2437. 61 center/66 outers. numbers on metering blocks are correct also. studying the base to see if I can drill it for ported vacuum.
1965 short bed
1965 short bed
- jkimbrel65
Re: 3 carb
Hey Skip what jets are you running?
Mike
Mike
Re: 3 carb
jkimbrel65 wrote:That's a fe tri-power.Ask away Kenny We'll try to answer your questions.Sen me your mailing address and you can borrow my tri-power book Carbs are correct
Mike
Thanks for the offer Mike. It will be awhile before this hits the road.
1965 short bed
1965 short bed
- Uncle Skip
Re: 3 carb
Mike.
First, I changed my squirters from the 50cc units to the standard 30cc's and I'm currently running a 58 jet on the center carb and 62's on the ends. I'm not running a heavy carb, but I do have 10:1 flat tops. It seems to like this setup on the street. Mike Bratland suggested 62/67-68 but that seemed to be a little rich on the street. With the 58/62 combo I got a nice light brown patina on the plugs.
I'm also using a 5.5 power valve per this thread https://www.holley.com/TechService/FAQ.asp?category=Carburetor
