Rear parking breaking cables
Any place in Canada that would have the 2 rear parking brake cables for 1964 M100 I imagine they can be custom made local but just wondering if someplace has them already made. I heard there was a place in Ontario that makes cables for old vehicles.
Re: Rear parking breaking cables
I found a couple from "Special interest cars" in Ontairo they have them in stock. A couple local shops custom make e-brake cables but they were talk'n over a 100 for just 1.
tomrooster
Sometimes you can get the old ones to work by hanging them up and add a thin oil or wd 40 and let it seep down. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
coil up in a 5 gal bucket with diesel or trans fluid for a couple days works too.
Yes I've done that with cables over the years too. These were too far gone though. The front cable I got moving good again though.ICEMAN6166 wrote:coil up in a 5 gal bucket with diesel or trans fluid for a couple days works too.
HAYMAN: Just for giggles, try Gary Automotive, they are on South side, not far off Whyte Ave, and a bit west of 99 St, he is pretty good at sourcing the seemingly impossible:)
https://www.google.ca/url?sa=t&rct=j&q= ... 8588,d.cGE
Gary Automotive Ltd
Address: 10060 80 Ave NW
Edmonton, AB T6E 1T5
Phone:(780) 433-1425
Gary Automotive Ltd
If you have access to a scrap yard the driver or passanger side cable from 95ish nissan quest and its equivalant the ford aerostar I believe is what it is called will work. This is what I used for mine. I have a 62 short flareside and all I hade to do was , move the cable brackets to the other side of the cross member and lenthed the bent rod underneath. Just make sure you can get two driver side or two passanger side cables, the longer of the two they will swap right in.
I think this is my first post and im some what new to this forum
- therealjoeshmoe
i know these work on 65 - 66 i would imagine there isnt much difference on the merc's
raybestos part #'s
bc92313
bc92314
rear two brake cables
if you need the front as well its a
bc92295
getcha some!! lol
should be able to buy all three for under $70
raybestos part #'s
bc92313
bc92314
bc92295
getcha some!! lol
