new guy from ne fl
new guy from ne fl
Im new to the whole slick world. I few months back i purchased my next project which is a 66 f100 of course lol. It had alittle work done to it to kerp it looking decent and running. The truck has a straight 6 with 3 on the tree. I recently bought a c6 transmission to have rebuilt and swap out the manual to auto. Have other plans for the truck other than just the trans swap like suspension work and interi I r work. Will try and get some pics posted tomorrow
- jkimbrel65
Re: new guy from ne fl
from n al we like pics
Mike
Mike
I tried being normal once...
I've never started with a truck that looked that good. Looks like a lot of fun.
Thanks.... since getting it, its been a kept in the garage. Im in the works of getting a c6 transmission i picked up for cheap rebuilt to swap into the truck. I really want to do a column swap with a shifter on the column but will probably do a floor shifter n d I wn the road do a column swap eliminating the old column 3 on the tree.bruceandersson wrote:I've never started with a truck that looked that good. Looks like a lot of fun.
Other plans for the truck will be some interior work, replace the windshield n seals on the windows, new rims n tires and suspension work in the form of air ride. Work in progress....slowly
- therealjoeshmoe
PAINT THAT GRILL WHITE!!!!!!!!!!!!!!!!!!
SWEET TRUCK THOUGH!
SWEET TRUCK THOUGH!
Very nice looking short box. Keep us updated.
Hmmmm..... interesting thoughttherealjoeshmoe wrote:PAINT THAT GRILL WHITE!!!!!!!!!!!!!!!!!!
SWEET TRUCK THOUGH!
Thanks will doorangeRcode wrote:Very nice looking short box. Keep us updated.
so curious... I have with the extra parts that came with the truck a chevy big block alt; any idea what the "po" could have had in mind for it?
My guess, he was going to change to one wire alternator and some think the chevy is easier to do.
Johnny
Johnny
Hmm so should hold onto it? There a link to this one wire alt swap?longcabjohn wrote:My guess, he was going to change to one wire alternator and some think the chevy is easier to do.
Johnny
My theory is if it is not broke don't fix, but if adding a lot of load it might be needed. Others will add more but I would not rush.
Johnny
Johnny
Well eventually i will be adding a stereo and air management equipment for air ride but thats down the road. I do notice when giving it gas when driving the alt light on the dash flasheslongcabjohn wrote:My theory is if it is not broke don't fix, but if adding a lot of load it might be needed. Others will add more but I would not rush.
Johnny
So is there a how to on how to install mirrors on these trucks? I received some chrome mirrors for xmas and figured i ask before diving right in...appreciate any help
- unibody madness
First, Ford purists do not believe in putting non ford parts on a ford....that being said, the Delco Remy alternator known as a one wire alt. is called that because of tractor applications. In order to do the job right on your truck,you would run the charge wire off the big bolt up to the positive on your battery through a j block, starter relay, or amp meter. the I terminal on the small plug goes to the positive connection at that point in order to read correct battery draw. The II wire goes to your idiot light to excite the alternator. Search Delco Remy for a wire diagram... look for the simplest that uses three wires.
In regards to mirrors it all depends on what mirrors you got. they either go to your two ears, one on each door or get screwed to your sheet metal on the door, if you have western or tow mirrors.
viewtopic.php?f=32&t=18944
I have the round chrome set from lmc that use the ears.... im looking to switch the ears out to the chrome ones that came with the mirrors...
Will look into the alt swap
- unibody madness
both hold the ear on
