my 66 f100
Re: my 66 f100
That type of bracket will need to come off of a parts truck. Someone ont he list might have one sitting around.
Re: my 66 f100
Thanks... will have to make mine work until then etc.bruceandersson wrote:That type of bracket will need to come off of a parts truck. Someone ont he list might have one sitting around.
Re: my 66 f100
Curious do i get a internal or external balanced flexplate?
Re: my 66 f100
I probably shouldve added more info.... my truck has a 240/300 and the auto trans im swapping came from a 79 econoline 150 with straight 6.... with that being said, for the flex plate am i looking at one that is balanced or not bslanced? Thanks66redrider wrote:Curious do i get a internal or external balanced flexplate?
Re: my 66 f100
So pulled the truck out of the garage today and installed my passenger side mirror and took her around the block.... must say i cant wait to get the transmission swapped over and will need to look into improving the manual brakes and what a chore to turn without ps lol
Re: my 66 f100
i am gathering up parts an i believe im close to the transmission swap....
What i have:
-c6 trans rebuilt
-kickdown cable
-trans cooler with lines
-trans mount
-flexplate
What i still need (feel free to chime in on something im missing):
-floor shifter (probably going with a b&m)
-new starter
-driveshaft
I feel like im missing items that are needed so again feel free to chime in....appreciate the help
What i have:
-c6 trans rebuilt
-kickdown cable
-trans mount
-flexplate
-new starter
-driveshaft
Re: my 66 f100
I just changed out a COM for a C-6. I bought a case of amsoil and had 1 and about a third of a quart left.
Ross Swearingen
1965 F100 "MIKI"
1965 F100 4x4 looking for a new home
1965 F100 "MIKI"
Re: my 66 f100
I should say that was for the torque converter as well.
Ross Swearingen
1965 F100 "MIKI"
1965 F100 "MIKI"
Re: my 66 f100
So im looking to order a few more pieces for my transmission swap and was wondering what size and style fittings would i need for the trans where the cooler lines hook up to it? Looking to run hose instead of braided lines. Thanks
Re: my 66 f100
Well the carpet is ordered
Re: my 66 f100
I was getting ready to ask the question of what linkage you used for your C-6 swap. Never mind I saw the floor shift. I have a C-6 and getting ready to swap the New Process four speed out and C-6 in.
Michelle
Re: my 66 f100
Yeah i went with the starshifter from b&mMichelle wrote:I was getting ready to ask the question of what linkage you used for your C-6 swap. Never mind I saw the floor shift. I have a C-6 and getting ready to swap the New Process four speed out and C-6 in.
