"Generator-Issues"
"Generator-Issues"
The Generator On Connie's 62' Isn't Charging. Generator Was Rebuilt With Bearings, Brushes & New Armature 2-Years-Ago. The Battery Was Recently Replaced, Is It Possible It Needs To Be Polarized? And If So Do I Arc The Field To The Battery Wire On The Voltage Regulator To Accomplish This?? Any Help From The Crafty-Veterans Would Be Greatly Appreciated. Thanks...............
Re: "Generator-Issues"
Can't hurt! Well, actually it CAN hurt, but only for a short while ! I seriously doubt that is the problem, though! DO NOT arc from field to battery terminals! Disconnect both wires at the regulator and touch them together momentarily.
Paul, What Do You Think Would Be Causing The Problem? The Voltage Regulator, Maybe A Bad Ground?? ...........Toyz wrote:I seriously doubt that is the problem, though!
could be as simple as one of the brushes stuck in its cage,so as not to make contact with the armature
i have seen this many times
Yep... I little whack with a hammer might get it loose & it will start chargingICEMAN6166 wrote:could be as simple as one of the brushes stuck in its cage,so as not to make contact with the armature
If it does.. Time for some maintance
Yep, I was about to describe a lengthy procedure related to temperature compensation, etc.! Reality is, the voices of experience provided Step One!slick4x4 wrote:Yep... I little whack with a hammer might get it loose & it will start chargingICEMAN6166 wrote:could be as simple as one of the brushes stuck in its cage,so as not to make contact with the armature
The Starter On My 65' VW Bug Had The Same Issue. I Had A Small Ball-Peen Hammer I Carried With Me. .. Thanks Guy's...slick4x4 wrote:Yep... I little whack with a hammer might get it loose & it will start chargingICEMAN6166 wrote:could be as simple as one of the brushes stuck in its cage,so as not to make contact with the armature
Really no need to carry a hammer; there is always a GM owner around with one wrapped up in a portable creeper, AKA carpet remnant!Shadow wrote:The Starter On My 65' VW Bug Had The Same Issue. I Had A Small Ball-Peen Hammer I Carried With Me. .. Thanks Guy's...slick4x4 wrote:Yep... I little whack with a hammer might get it loose & it will start chargingICEMAN6166 wrote:could be as simple as one of the brushes stuck in its cage,so as not to make contact with the armature
