1966 4x4 LWB Future project!!!
MNTBUGGY
Post by MNTBUGGY »
Well I guess I should stay off craigslist :mrgreen: . Was searching and found this 1966 F100 LWB 4x4 pretty much original truck (F11YK747579 ). The door tag is still there. The motor (Y code) has been changed out to 360 or 390 by decal on valve covers (1973 vintage). It is a custom cab ( C81) , paint code ( B) Caribbean Turquoise, Axle code (08) 3:50 gears. It runs (kinda needs tuned up / carb rebuild) and drives even has brakes. It has been sitting since 2009 ( dates on plates). Looks like it was originally sold in Golden CO by the dealer sticker on it, it went to South Dakota where the seller I got it from had it for a couple of years in NW Iowa. Only a mere 500 miles from my house. So loaded up the trailer and my son and off we went. I knew it was gona need floors but after further looking will probably need to find a donor cab. It came with an extra pair of fenders (not to bad) I am going to change them out and put one of my spare bumpers on the front. Gona be a project for a later date (retirement??). I will put it in the back of the building next to my 66 F100 SWB 4x4. Try and pickup parts here and there.
x
x
x
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1961 F100 Unibody ( Son's)
1969 Chevelle SS-396
1966 Jeep CJ5
1966 Mustang coupe (wife's )
aj64f100390-292
Re: 1966 4x4 LWB Future project!!!
Post by aj64f100390-292 »
MNTBUGGY wrote:Well I guess I should stay off craigslist :mrgreen: . Was searching and found this 1966 F100 LWB 4x4 pretty much original truck (F11YK747579 ). The door tag is still there. The motor (Y code) has been changed out to 360 or 390 by decal on valve covers (1973 vintage). It is a custom cab ( C81) , paint code ( B) Caribbean Turquoise, Axle code (08) 3:50 gears. It runs (kinda needs tuned up / carb rebuild) and drives even has brakes. It has been sitting since 2009 ( dates on plates). Looks like it was originally sold in Golden CO by the dealer sticker on it, it went to South Dakota where the seller I got it from had it for a couple of years in NW Iowa. Only a mere 500 miles from my house. So loaded up the trailer and my son and off we went. I knew it was gona need floors but after further looking will probably need to find a donor cab. It came with an extra pair of fenders (not to bad) I am going to change them out and put one of my spare bumpers on the front. Gona be a project for a later date (retirement??). I will put it in the back of the building next to my 66 F100 SWB 4x4. Try and pickup parts here and there.
x
x
x
nice find!, when you get the chance post some more pics if you would. Show use the rust :lol: if that cab has to be replaced that sucks..still runing the original seat cover....is the floor mat still there?
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
MNTBUGGY
Post by MNTBUGGY »
I think the original floor mat is there the floors are nbad enough that it has multiple holes in it. The driver's side of the lower front all layers are gone. Gona put some different front fenders on it. Will get a better idea of how bad the rust is the then. The seat cover is tore up.
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
FarmMotorSports
Post by FarmMotorSports »
Noticed that add this weekend my self.... looks like its not as good looking once it's out of the garage.
Thanks for removing the temptation.
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
MNTBUGGY
Post by MNTBUGGY »
The only big surprise was the cab was worse than I thought it was Gona be. Expected the normal floor rust . The plus side is it is all there and it drove on the trailer. The 4wd trucks are are hard to find around here. He came down on his price. Gona play around with it. The good thing is the cab is the same as 2wd for the 66 so it is a findable part. Something else to keep myself amused in the garage.
On the positive side the hood and doors are rust free, the tailgate will need minimum rust repair. A nice set of front fenders came with it. Looks like the windshield was recently replaced.
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
04sd
Post by 04sd »
Very nice truck.
MNTBUGGY
Post by MNTBUGGY »
Well decided to do some basic maintenance before I put it up. Change the oil/ filter, plugs and rebuilt the carb. Figured that who knew when the last time the antifreeze was changed. Drained the radiator and then pulled the lower hose off and saw there was oil in it !!!!! Probably a bad head gasket. There was no antifreeze in the oil. On the positive side it seems to run pretty well and went up and down the driveway without any scary noises!!! Gona pull off the bumper and fenders and replace then with some spares!!! Then off to get the Highway patrol to do a VIN # inspection so I can get the title in my name. I will post some pics later after the bumper and fenders are replaced.
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
MNTBUGGY
Post by MNTBUGGY »
Couldn't stand looking at the curled up / rusty fenders so changed them out with the set I got with the truck. Had to put a little rattle can primer on them the baby blue was not gona pass!!! Dug around and found a bumper that was straighter than the one that was on it. Gave it a bath and it looks much better. Here are some pics of it cleaned up.
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
Anthony
Post by Anthony »
way to go!! it looks a lot better with just the fenders and bumper.. :) looks like it could be a nice ride.. Love those 4x4's!!
bruceandersson
Post by bruceandersson »
Now it can rest in dignity until you're ready to bring it back.
MNTBUGGY
Post by MNTBUGGY »
Since who knows when I will get started on it if it looks better it will get me more enthused.
Now it's time to start gathering parts here and there. They are always easier to find when u don't need them. I have always liked the 4x4's. Since my first slick in about 1980!!
bruceandersson wrote:Now it can rest in dignity until you're ready to bring it back.
. So true
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
That's the truth. You find parts when you don't really need it. And you seem to have money then too...
MNTBUGGY
Post by MNTBUGGY »
Well got the truck put away until another day!!! Time for hunting and gathering of parts.
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
aj64f100390-292
shipwrecked wrote:That's the truth. You find parts when you don't really need it. And you seem to have money then too...
Man is that how it goes or what... :wink: I found a pretty decent 66 auto yesterday and a cheap one at that...have no place to keep another project...someday I gotta get the stock pile MNTBUGGY has..makes me drool.. :lol:
MNTBUGGY
Post by MNTBUGGY »
The SWB 4x4 I bought about 7 yrs ago and got some of the work done on it and put in the back while I worked on my wife's car 66 mustang coupe. It is done now so the father/son project with his 61 Unibody Short bed is now under way (well at lest moved to the garage from the back). When we get some work done on it I will post some pics.
Just find parts and then find nicer ones so the piles get bigger!!!!
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
therealjoeshmoe
Post by therealjoeshmoe »
dude that shop tho!!! :notworthy:
Image Image Image Image
orangeRcode
Post by orangeRcode »
Lookin good dude!
Did any of the nuts give you fits? I broke the bolts holding the front bumper on my 65. Several of the encapsulated nuts are giving me fits on the grill. About to pull the core support off with it. Either that or get a torch wrench.
