Do old trucks get arthritis?
jeepbut
Post by jeepbut »
The doors on Grace slick stick when it rains. I have oiled everything. There is not enough door rubber left to affect it. Cab mounts good. Door operate fine once the sun has been out a few hours. Passenger side is the worst. Takes a real good yank to open it. Any clues other than the arthritis theory?
Re: Do old trucks get arthritis?
I could understand a wood door doing that
Swelling & making things tight....
But that shouldn't effect metal
I could see an old truck that had a bunch of
Trashy stuff in the cab corners getting wet & swelling
Your truck is probly clean though.....
jeepbut
Post by jeepbut »
Very clean Pat. No obstruction of any kind that I can find. Halloween is coming up. Haunted maybe?
jamesdfo
Post by jamesdfo »
I suspect that one of the previous owners used your truck to haul chickens to the slaughter house.
The problem you've described could be caused by POULTRYGEISTS. :rotflmao:
^^^^^^^ :roll:
LM14
Post by LM14 »
Wow........just ....wow.......
Is it in the door mechanism? Maybe the grease isn’t the right kind?
jeepbut
Post by jeepbut »
It is both doors. Right sticks more than left. Only started this two or three rains ago. Weird. I can't wait for the next rain so I can play with it.
Is it the same getting in as getting out Lyman ?, could be the door mechanism has a load of grime on it and that holds moisture when it's raining
and that stops the keeper from moving all the way back and catching just a little, making it harder to open the door... or move to a dryer climate !! .. :lol:
64 f100
Post by 64 f100 »
Lyman, it just does not want to go out in the rain. You should treat it better. :lol:
jeepbut
Post by jeepbut »
96 F-150 in shop for clutch so I drove Grace Slick. Rain came, sticking doors came with it. Spent lunch playing with it. Cleaned hinges and latches with de-greaser first. Tried spray oil, atf, motor oil, 90 weight gear lube and finally some blue high dollar electric motor grease. Nothing helped. I think it may in fact be haunted. Oh well, it started out of the blue, maybe it will stop just as suddenly.
Just like our old bodies Lyman, we know what will hurt and we just work around it, same with these old girls seems !
