Sound of fluid rushing forward on start up
Chef_Zimm
Post by Chef_Zimm »
After siting for a while I hear a rush of fluid (gas I am assuming) from behind me moving forward towards motor. Is this normal? It sounds to be on the pasanger side....
Thanks ahead of time guys!
Re: Sound of fluid rushing forward on start up
You might have to give more details
Engine ? Trans ? Mostly stock ?
You can hear this while the engine is running ?
Never been able to hear fluid really....
The heater might have antifreeze running thru it
Hard to beleave it would make much sound.....
Usally only can hear exhaust leaks & vacume leaks
Chef_Zimm
Post by Chef_Zimm »
292, 4speed, completely stock. It last for a quick second right after the engine starts. You can hear it loudly rushing forward.
FarmMotorSports
Post by FarmMotorSports »
A little air trapped in the heater core... :2cents:
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
Chef_Zimm
Post by Chef_Zimm »
And is that something to worry about? Air in the heater core. How would I remedy that? It’s a new sound...
I would think if your coolant level is
Topped off... shouldn't be a problem
Are you sure it isn't the starter disengaging ?
Can you start it , run 15 seconds , shut off...restart, does it
Sound the same way... or just after sitting a while ?
Chef_Zimm
Post by Chef_Zimm »
Only after sitting a while. It clearly is fluid and air gurgling.
tomrooster
Post by tomrooster »
Like Farm says (A little air trapped in the heater core...) check your coolant level . Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
64 f100
Post by 64 f100 »
Like my uncle always said if it makes a noise you don't want to hear turn the radio up. :lol:
FarmMotorSports
My experience is if it's full of coolant, and kept full, it will eventually work it's way out of the heater core.
The more you use it the sooner it will happen.
But it's just noise, and shouldn't cause any other problem.
61 F250 Unibody
unibody madness
Post by unibody madness »
On the other hand if it does it every time it sits for awhile, you may have a leak in the heater core, or heater hoses that is tiny enough to not be noticed.
I would take the cover off of the heater box and check for obvious signs of a leak that will cause rot.
Easiest way to check is to loop a hose at the water pump so you bypass the entire heater system.
As noted on the “other” site, this is quite often symptomatic of reversed heater hoses.
