1961 F100 Unibody SWB Project SOLD
Show truck, daily driver, or parts truck - if your looking to sell a whole truck, post it here.
MNTBUGGY
Post by MNTBUGGY »
1961 SWB ford unibody truck. I started off with this as a project for myself but it is time to let it go. The truck has no motor or trans in it. The front fenders and doors are rust free, the bed is nice and is not rusted out at the front where they usually are. The floors, cab mounts, steps will need to be replaced. I have new patch panels for the steps and front door posts. The hood is nice it has a little bit of rust coming thru on the front lip . Radiator support is usable but it will need repaired. All glass is there. The tailgate will need some repair around the hinge. I have the tailgate rods for it ( usually lost). I have several other body patch panels/ parts that I have cut off other trucks that go with it. It has a 62 chrome grille in it.
It has a 3" drop front axle, 3" drop reverse eye springs ( 6" drop ) , Disc brakes, Power brake booster , master cylinder, proportioning valve. The wheels are 15".
Clean Kansas title in my name it currently a non-highway so when you get it running take it to KHP inspection station and they will issue you a highway title.
$ 2900 OBO
https://wichita.craigslist.org/cto/d/19 ... 56141.html
Mike 316-209-6222
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1961 F100 Unibody ( Son's)
1969 Chevelle SS-396
1966 Jeep CJ5
1966 Mustang coupe (wife's )
MNTBUGGY
Re: 1961 F100 Unibody SWB Project
Post by MNTBUGGY »
Lots of lookers!!!
More info :D
The bed and doors were blasted so there is nothing hiding under the primer. The new patch panel parts ( front hinge pillars (usa), step plates, step plate risers, rocker panels (usa)) were close to $500. The drop axle, springs, disc brakes, brake booster were about $1500 new. It still has the stock 9" under it not sure what gear is in it.
Mike
Mike
1966 F100 4x4 SWB
1966 F100 4x4 LWB
1966 Jeep CJ5
