Installing new pre-bent brake lines on my 65 F-250 and I need the block that came from or will fit a 1967 F-250.
FOUND, DELETE: 1967 Manual Drum Distribution/Switch Block
Re: 1967 Manual Drum Distribution/Switch Block
I've got 65/6 style, but not a 67 as far as I know. Got a picture of one?
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
Day2; I did not check with them but the link has disc drum block for 60's-70's. I am slipping 67 lines and manual master cylinder. I am keeping the four drums.64 f100 wrote:I've got 65/6 style, but not a 67 as far as I know. Got a picture of one?
Rich, I have a picture of my 65 but never could get my pictures minimized to work on this site. I am hoping the rear drum/drum line would bypass the block but I do not know.
If you see something I missed could you provide the link?Day 2 wrote:Have you checked here? https://www.carolinaclassictrucks.com/F ... valve.html
Without seeing what you need its going to be difficult to recommend . Is the M/C dual outlets? If so why not just run an adjustable p-valve? Is the block you are looking for a p-valve or just a straight thru distribution block? Sorry I can't be more helpful.
Robert
Robert
- unibody madness
If you are keeping the drums all around you do not need a p valve, a distribution block would work to make things easier but simple Block tees would work also.
I would look for a distribution block from your trucks era for a vehicle with four drums. pick and pull is your friend. Mine comes from a jeep cherokee or comanche on two of my trucks its a simple brass block. Ford has a great distribution block of the early era for a drum set up, compact and ford correct but they are getting harder to find and have never seen them reproduced.
viewtopic.php?f=32&t=18944
