What Slick60s Engine Transplants Have You Seen?
chris401
Post by chris401 »
I've seen Coyote and Cummins swaps. How about a Triton V-10 or Perkins 6.354?
jamesdfo
Re: What Slick60s Engine Transplants Have You Seen?
Post by jamesdfo »
Haven't personally seen a 6.8 V-10 in a Slick, but I'd expect by now, someone has done it.
I do know a local fellow who's in the middle of doing the 6.8L swap on a Bumpside ('71 XLT), and being as his last swap was the Lincoln 4.6L DOHC 32V into a '57 Ford SW, I expect the Bump will be nicely done:)
FarmMotorSports
Post by FarmMotorSports »
A quick YouTube search "Perkins Ford" will net you several from South of the border...
I believe we had an Ecoboost build here at one time...
Mention of a Mercedes build but never heard of the results...
I've heard talk of a 'two stroke' Detroit in a Ford...
How about something rare, 427 overhead cam side oiler...
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
chris401
Post by chris401 »
FarmMotorSports wrote:A quick YouTube search "Perkins Ford" will net you several from South of the border...
I'd seen Martin's Perkins powered Crew Cab but no Slick60s. The 5" stroke would get the load moving.
Johnny Canuck
Post by Johnny Canuck »
The other Pat the farmer, slick 4x4 had a bump with a Detroit in it. Never saw it personally, but hear it was Cool and LOUD.
and of course there have been many many 350/350 combos in these trucks, sad as it makes me.
there are many, many good choices out there why waste your time on the lowest common denominator..
Curmudgeon
Post by Curmudgeon »
I put a Briggs & Stratton 3.5 h.p. in mine. It will pull a house down the road in that granny gear . . .
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
we just brought in 61 uni-bed Big back window short bed out of NM with 460 fuel injected in it air bagged 4-wheel disc BUT Hit real hard on Pass. side
12649
chris401
Post by chris401 »
6166 Junkyard Dog wrote:we just brought in 61 uni-bed Big back window short bed out of NM with 460 fuel injected in it air bagged 4-wheel disc BUT Hit real hard on Pass. side
Are there quality headers for a 385 Series to Slick?
6166 Junkyard Dog
Chris just peaking under the hood since it's raised up on pass. side it has stock exhaust manifolds rh side is pushed back a good foot if not more,, truck was insured by Hagerty, might have been a member truck here also ?
12649
