One Barrel Carb!!!
rickrob16
One Barrel Carb!!!
Post by rickrob16 »
Hey All! I am about to replace the 1 barrel Holley that came with my 61 F100. Any suggestions on what to replace it with? I want another 1 barrel carb. I have looked around the internet. haven't seen much on quality new 1 barrels??? Any suggestions are appreciated! Thanks!!!
Post by Gritsngumbo »
Why are you replacing the carb?
Kid
Post by Kid »
I had a Motorcraft and a Holley that were both junk so I am running a Carter on it now and it is great. Gas mileage went up and so did performance and reliability........Kid
DanSanDiego2000
Direct question.... indirect answer
Post by DanSanDiego2000 »
I know you said you wanted recommendations on a 1-barrel, but the only recommendation I'd have is "Don't do it" ;-) I found an NOS 1-barrel on eBay a couple years ago, ran it, liked it, had to rebuild it, then converted intake, carb and headers.
I was going to bolt a 2-barrel in place of my 1-barrel, but instead changed to a Clifford Intake and headers, and a Holley flanged 2-barrel.
I still have the 2-barrel/1-barrel adapter I purchased from Clifford. It is designed to bolt onto your stock manifold, and accept the smaller style 2-barrel (the small rectangular base plate).
If you want a 1-barrel, I can't help. If you want to consider a 2-barrel, I may be able to help you adapt.
cdherman
Post by cdherman »
I would agree with Kid that if originality is not an issue, then the only 1 bbl carb I would mess with is a Carter YF.
Kid is running a carb that I rebuilt and later let him buy from me.
I have a $350 dollar Ponycarb highend rebuild (they do them for the Concours Mustang boys) and my rebuilt Yf runs BETTER.
I think a lot of people give up on 1 bbl setups because you just cannot go buy a rebuilt 1 bbl from a parts place and get them to work. But the good news is that they are not hard to rebuild yourself.
Pick up a used, decent looking MANUAL CHOKE YF off of ebay. rebuild it (parts kit is $20, comes with instructions), get a junkyard or JEGS aircleaner, rig up the choke linkeage (not a problem, I will post link to my website if you need help) -- the throttle link is bolt up, at least on a 65 it was.
I am assuming you are running this on a 223. The 2bbl setups are probably overkill, and may actually run worse. Over at fordsix.com its the YF that also gets recomended.
1683
Planned/considered upgrades:
Tech
Post by Tech »
I like the Autolite 2100 2 barrel with the small ports for the 6's. They start nice are cheap and simple to rebuild. The economy isn't bad either. I put one on an industrial flathead 6 complete with electric choke and an electric fuel pump. It can sit for six months and still start like it ran yesterday.
Tech
