Slickmainers (Gregg) 65 project
Pretty sweet deal on the shop.
Now you know that there is no place to stop on the truck. It just keeps multiplying on what more you can do. But it is worth it when it's done.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
- slickmainer
i do plan on painting the frame, painting the underside as best as possible, and redoing the front and rear brakes, mounts and bushings. I have about $1200 set aside to get it to a mix matched exterior driver status. then body work and paint the following year.
smartly done I should make it since the engine and tranny are fine, doors are good, fenders are good, and frame is solid.
--Gregg--
you can't get there from here
- slickmainer
small update. I've opted to buy this cab from Cape Cod and stick with my 65.im going to save a little money and just keep it on the same frame. I kicked around the idea of a 77 frame swap, but i wanted a bed that looked right more than i wanted power steering and disc brakes, and kinda wanted to keep it all together.
anyway, im getting it this weekend weather permitted. then having it sandblasted so i can start to do metal work on it and see what i have. I do see lots of spray primer around many holes like where the hinges go and along the dash, but maybe they did that as a preventative measure??
uncut dash
looks like "open door light" switches on each door jam
good cross supports and corners
good floor (i hope)
solid mounts (i hope)
got some floor to patch
woohoo!
damn
uncut dash
good floor (i hope)
woohoo!
damn
--Gregg--
- slickmainer
I'd say that's a pretty fair price Gregg.
Not much to fix at all on it. You can cut the one off your truck up for patches.
You do know you can upgrade the steering & brakes on the frame you have.
Glad you are settled on a plan and are fixing the truck.
- slickmainer
- slickmainer
- slickmainer
- Hookedtrout
Wish you were closer, I'd give you a dozen GPS coordinates for all the slicks I've seen just waiting for someone to take them in and bring them back to life.
Cory
1962 F100 SWB Unibody, 223
1931 Ford 5 window coupe
