Michelle's 65 Ranger Rebuild
- Reds Rod Shop
Michelle, your build is looking good. It makes me feel bad for neglecting mine for the past few weeks. Keep up the good work and the updates. Red
Red
My 1964 Restomod Project http://fordtruk.com/forums/viewtopic.ph ... sc&start=0
I got the chassis painted and have started the rebuild of my engine. I am not really doing a rebuild only freshing up the engine with new gaskets, valve seals, cleaning the combustion chambers and installing new freeze plugs. When I removed the old freeze plugs they looked near perfect on the back side. The engine is very clean inside.
Michelle
- Alan Mclennan
OH great Michelle!, your`ve nearly caught up to me already!
Today marked a major milestone. I got the engine and transmission back in the frame. Tomorrow I will take the wheels to discount tire and have the new tires put on.
Also I have up dated my Ranger page.
http://www.michellesfords.com/RangerPage.html
Michelle
- slickmainer
wow thats purdy. so is that a NP435? I thought I had that in mine but my book doesn't look anything like that one. Granted a boot doesn't tell you much and I'd have to look for a code but still. I guess mine could be a later T18. right and down for reverse. clearly I should look before asking.lol
--Gregg--
you can't get there from here
Yes, as long as the Lord is willing, I will be there.Paranoid! wrote:Wow!!!
That look's great Michelle......
So are you bringing this to SS?
Michelle
I spent the day yesterday working on my chassis. I installed new shocks all the way around. Removed all the drums to check the brakes and blow out all the brake dust and sand from the sand blasting. Repacked the wheel bearings installed new wheel seals. Installed the alternator, starter, clutch Z bar and universal joints, I got the front drive shaft in and will install the rear shaft today. A couple of days ago I installed the fuel pump. When doing so I noticed that the right fuel pump bolt would not tighten up. It very quickly became obvious that the threads in the front cover was stripped. I already had the pan, water pump and balancer on, I was not too thrilled about removing all of that and buying new gaskets just to get it off so I could install a helicoil or replace the front cover. So plan B went into effect. The two bolts that hold the pump on are 3/8, I took a 7/16 tap and tapped out the hole and then took a 7/16 bottom tap and finished the job. Drilled out the right side hole in the fuel pump with a 7/16 drill and installed the fuel pump with one 3/8 bolt and one 7/16 bolt. It works and saved a lot of time. Sorry no pictures today.
Michelle
I have finally got started on the bottom of the cab. I tilted it back on its back side and started the replacement of the cab crossmember ends. I also have some front cab mounts coming, they sould be here next week.
The bottom of the cab is pretty rust free except for the cab crossmember ends and the front cab mounts. I am going to sand blast it this evening.
The gray paint on the fender is POR 15, You can paint it over scaly rust and it will stop it in its tracks. I however don't like to do that so I sand blast it first where I can. I used it in the front recesses of the fenders where it gets accumulations of dirt from driving. It is water thin and you can brush it in hard to get places and then turn the fender up and it will gravity feed down in the cracks and crevices that you can't reach with a brush. It amounts to some cheap but good insurance.
Michelle
Michelle wrote:I have finally got started on the bottom of the cab. I tilted it back on its back side and started the replacement of the cab crossmember ends. I also have some front cab mounts coming, they sould be here next week.
The crossmember ends look like a good place for weep holes. Thanks for the progress reports. I have learned a lot watching your build.
Jim
