Ditto ... I was thinking they were old MB seats also, I don't know why, but I think it's the shape of the headrests that was the clue. Such fun !!!Brian Taylor wrote:Can not wait to see the finished product. Not sure but those look like old Mercedes seats. The Archeology is the most fun.
whistles 66 camper
- olliesshop
Tim - 1961 F250 Uni
It hasen't rained in couple weeks so I decided to take the roof off.
I wonder if I'm starting a project or opening a can of worms.
Minor water damage huh sure thing. I know all the cabinets are good so with the roof off I can remove and store them and then jump on the walls.I'm takeing lots of pics and measurements of how it's built and wired. Already saw a lot of improvements I can make in the construction. I got a little hot so now I'm in the house cooling of and drinking a pepsi.Maybe do a little more when it cools of.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
- Hoofbeat Racer
Well, I got quite a bit done on the camper today. First, I pulled all the doors and windows. Then, I pulled all the skin off of the right side. Now, I've mentioned the phrase "slight water damage" before, well here is a prime example of slight water damage.
This camper is not repairable, a friend told me I had a good start on a flat bed. But, being the hard headed cuss that I am, I still want it to be a camper. So, I will take carefull measurements of everything as I tear it down and transfer them to this picture. Then, I will have a blueprint and picture in one. I thought I could reuse the cabinets, but there is some water damage to them, also. Maybe, I can replace the damaged areas and reuse them because I want something from the original, so it wont be a completely new camper. Seeing as how it's not repairable, I will have to tear it down to the frame and rebuild from there.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
- ezernut9mm
hey, at least it's not a pass through cab. lol
- olliesshop
WOW !!! You have some work ahead of you. That's much worse that I was hoping for you. I'm glad your going to keep it a camper, though. Are you going build it out of wood or use steel for the framing, etc.?
Tim - 1961 F250 Uni
While it's not a true pass through the rear window has been removed and a rubber adapter of sorts connects the cab and the camper.
I plan on rebuilding as close to origional as possible. It will have a wood frame with quite a few upgrades. It plan on geting all new appliances. I would like to go all electric but thats not feasable. I need LP for the fridge and range.I am going to replace the furnance with a roof mount heat pump for heat and AC. Suprizeingly the appliances are not all that costly.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
- F7BIGJOB
Check the roof mount a/c-heat pump info first, the heat pump will take the edge off, BUT will not operate at temps below 40^f.rwhistles wrote:While it's not a true pass through the rear window has been removed and a rubber adapter of sorts connects the cab and the camper.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
-Steve
- F7BIGJOB
OK= I'm in the RV industry and thats a common complaint in New England as the owners do not want to use their lp gas, they rely on 'free' campground electricity and right now temps will not allow heat pump to operate.
Must be nice to not go below 40^ at your house
It's here.
F7BIGJOB
-Steve
-Steve
- Alan Mclennan
Rick, is that 29 F or C, if it`s F, I`m crossing KY off the visit in winter list!, ouch!rickairmedic wrote:LOL Steve I grew up in Tampa , Fl. But I live in Louisville,Ky. The current temp here is 29 with a feels like of 21 and thats the warmest it has been here this week . I feel your pain.
LOL its F and while the berry farmers were freaking out down there at the 24F temps it was in the single digits here with feels like temps in the - F area . I watch the weather channel regularly and always get a kick out of their corespondents standing out in the berry fields down there in Plant City playing with the ice encased berries .
I'm think flatbed, but it should be a fun project for you. Have you created a cost sheet and compared it to what a new camper would cost? While it wouldn't be original, a new camper on a '66 would be very cool.
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
