My 62 shortbox build
The Big M
Re: My 62 shortbox build
Post by The Big M »
That's the kit I was thinking of, and I'm curious what the final selling price ends up being. Some serious potential there.
Looking forward to seeing this with the fenders on. The high-back buckets look good in there too.
The Big M
Post by The Big M »
jamesdfo wrote:That four link looks good as well, my only question is how far above the original elevation of the box floor will the kickup protrude?
Based on the info posted on the Industrial Chassis website I believe the kit shown is the maximum drop, which has about a 5" c-notch built in. They're apparently doing one that matches the height of the stock Dakota IFS kit as well, which I suspect would require much less of a notch in the rear rails.
Alberta62
Post by Alberta62 »
Had to see it with the front clip stuck on. It's the first time since I've owned it that it's been this complete.
62 Unibody shortbox, 5.0/AOD, Dakota front end, rear axle over
viper driver
Post by viper driver »
Great start! Front looks just right
Brucekoukalaka
Post by Brucekoukalaka »
Looking good!
They wouldn't hire me at A&W so I became an automotive technician!
The Big M
Post by The Big M »
Excellent result! The wheel placement looks spot-on.
Alberta62
Post by Alberta62 »
Chose to take the cheap and easy way for now. Axle over spring kit.
390fastback
Post by 390fastback »
Over axle is the way I did it....as you said 'for now'!
Bottoms out a lot.
plus many other's!
Alberta62
Post by Alberta62 »
Did you put a c notch in yours?
The Big M
Post by The Big M »
Nice progress, that looks like a good amount of drop. :thumright:
390fastback
Ya I did, and it still bottoms.
plus many other's!
Alberta62
Post by Alberta62 »
That's what I'm afraid of. Small price for having a cool looking truck.
390fastback
I'm hoping this summer I have time to put the Lincoln Mark VIII IRS I have in it. Should solve that problem.
plus many other's!
Dakota Kids
Post by Dakota Kids »
I Like it ! I went with the four link I may have overbuilt it.
If you ask me anything I don’t know, I’m not going to answer.
Yogi Berra
Alberta62
Post by Alberta62 »
I've been looking at Mark VIII IRS setups. There is a little info on the site here but I'm looking for more. I have a line on a low mileage setup and trying to decide if it's the way to go.
I am not a suspension expect!!! Just my thoughts. IRS is interesting in theory, but it seems I see a lot of IRS cars going down the road with obvious rear suspension alignment issues, mainly keeping the rear wheels in a vertical plane. If you want to autocross or rally race, it may be the way to go. If you want simple reliability a normal diff may be a better choice. I think with the correct setup, you can get similar performance without the complexity of the IRS.
