62 unibody build
twistedfreak
Post by twistedfreak »
might do the white that its getting two toned in thast would look good also
""WE THE WILLING, LED BY THE UNKNOWING, ARE DOING THE IMPOSSIBLE FOR THE UNGRATEFUL""
twistedfreak
got the gas pedal installed tonight and all the items off that im taking to get blasted tomorrow so i can get them coated. ill get the picks asap
Reds Rod Shop
Post by Reds Rod Shop »
Definately painted valve covers IMHO. I agree with painting the lines. The contrast will make them stand out. Can't wait to see the pics of the gas pedal. I'm at that point on mine. What kind did you use?
twistedfreak
firewall mount from a 65 f100 just didnt use the braket that the 65s used
twistedfreak
heres the pick of the pedal i hope that it helps those that dont want it on the floor so if so great and if not let me know and ill try and explain why.
twistedfreak
got the parts back from the blasters today and started working asap so here ya go ill get them all up when im finished with them and more to come
twistedfreak
heres the rest
noley99
Post by noley99 »
Man that looks good, what color are you going with the engine?
Family First!
twistedfreak
going to go the white that the top half of the truck is going
twistedfreak
got a ton done today out in the shp on the rod ill get picks up after dinner
twistedfreak
Reds Rod Shop
Good Progress man. Seeing others make progress is what keeps me going. Keep up the good work and the pics.
twistedfreak
some quick picks from tonight
what gas tank are you guys using for the tank between the rails mine is from a 64 mustang im thinking about making one to fit perfect and maybe a little bigger than the mustang
deflaytedwayz
Post by deflaytedwayz »
Pretty sweet looking project ya got there
twistedfreak
the other side
twistedfreak
I know I've seen it somewhere on here the install of the crown vic front end swap but now that I bought mine i can't find it so any help would be great
tomquist
Post by tomquist »
Here's a good thread from the "other site"
http://www.ford-trucks.com/forums/71605 ... f100.html
twistedfreak
picks of the front end on
twistedfreak
well i have the frame now turned right side up and the cv front miunted close but with some more measuring ill be better and my only bugger is now figuring out how to get my welder and plasma over in the other side or i might just suck it up and run some 220 cable over and add a plug and some light so i dont have to use my stand light over there with an extension cord but it works for now.
twistedfreak
pick with the front end on but couldnt get a front view to bright also got the pass floor welded up solid and starting smoothing out the firewall as the floor cools and cleaning the underside of the truck and painting it tomorrow
