Dan's 1963 F100 split uni (with cross flow radiator)
bobenhotep
Re: Dan's 63 wrongbed "the iron rhino" (soon to be a uni bed
Post by bobenhotep »
Finally got the bed cut off of the uni
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
64f100sixcylinder
Re: Dan's 63 wrongbed/split uni "El Gaucho" (updated 25 Aug
Post by 64f100sixcylinder »
why did you cut the bed off?
HawaiiKid
Post by HawaiiKid »
Very interested in seeing how this turns out!
http://slick60s.com/viewtopic.php?f=32&t=28059
64f100sixcylinder wrote:why did you cut the bed off?
he wants a south American style slick
as do i
heres a pic of the bed i cut up in Alaska
i cut the top differently and was in the process of removing the gas tank brace and the other angle piece which i was going to replace with flat stock bars 1" x 3\16" to strengthen the wall some.
foodstick
Post by foodstick »
The real key is to find a uni where the cab is too far gone..and the box is good enough...
Dan that box looks like it was a pretty easy job to get off there.
So from here you just have to close in the gaps in the the front of the
box and then start pounding out some dents here and there. As I recall
one of those tail light areas needed a little help too. Maybe I can find you
a replacement panel you can use. Might make things easier. TR
bobenhotep
Thanks. I cut it a little on the long side so that I could cut it down to size, since it is easier to take away than to add. My next step is to turn it upside down on sawhorses in front of the shop so I can do repairs on the bottom. I think I can hammer out the dents on the back, but any help is appreciated.
"The Iron Rhino"
-duraspark II/ HEI
bobenhotep
I finally got the bed off and in front of the shop for some cut and paste
"The Iron Rhino"
-duraspark II/ HEI
bobenhotep
I cut open the torque box. Full of dirt and rust.
"The Iron Rhino"
-duraspark II/ HEI
bobenhotep
After hosing the garbage out. Still work to do.
"The Iron Rhino"
-duraspark II/ HEI
foodstick
Re: Dan's 63 wrongbed/split uni ( as of 22 Mar 15)
Post by foodstick »
Gonna enjoy seeing this come around ! loven them split unis .....
bobenhotep
The bed is in the shop. El Nino has been at work here making it rain, which is unusual in May. You can see where I reconstructed the piece that holds the sheet metal in place on the lower bed. I used 2 inch angle. I also welded a piece across the front of the bed. I did it as one piece so that it will be straight. I am going to cut the middle out of it and drop it 1/4 inch for the bed floor, which I am going to cut out of my fridge bed.
"The Iron Rhino"
-duraspark II/ HEI
foodstick
Re: Dan's 63 wrongbed/split uni ( as of 18 may 15)
Post by foodstick »
Is this truck going to be ready for episode 7 ? The Chijawas haven't been spotted in a sand crawler in quite awhile...
bobenhotep
I plan on having the body work done by then. The rest is easy stuff. I should have the hyperdrive ready for august 2016.
"The Iron Rhino"
-duraspark II/ HEI
bobenhotep
I welded in the support for the other side. I now need to weld in the front bed support.
"The Iron Rhino"
-duraspark II/ HEI
Re: Dan's 63 wrongbed/split uni ( as of 22 may 15)
good deal
keep going at it youll be done by ss
i would flip mine over but no one to help so its up on barrels and blocks
got my gas bottle yesterday so ready to start welding again
while hammering out dents in the wheelwells i started to wonder how many others have done or tried to do this uni bed thing
bobenhotep
More work finished. I welded in a solid front piece so that it would be straight. I also cut through it on each side so that it would be cut out around the sheet metal ribs on each side. I cut the center back out so I could weld it back in with the drop necessary for the corrugations in the truck floor.
It needed a 1/4 inch drop, so I welded a spacer made from angle scrap on each side.
On the center piece I cut out the pieces that would cover the ribs and become crap catchers.
I then welded the center back in. I clamped it and did some plug welds so that I would not have to keep clamping it.
"The Iron Rhino"
-duraspark II/ HEI
Re: Dan's 63 wrongbed/split uni ( as of 28 may 15)
So you plan to cut a section from the fridge bed to take the place
of the rotten rib section between the front and the first crossmember?
That will make that look a lot better. I knew you had planned to use pieces
from the fridge bed for that. Hope it will line up ok. Can't see why they would
make those ribs any different. They all look pretty much the same to me.
Keep putting pics up Dan, good to see that bed being reused. TR
unibody madness
Post by unibody madness »
Whole lot of watchin goin on
bobenhotep
No fridge parts yet. This is all 2 inch angle cut and welded in to replace the original sheet metal. I am going to cut a section out of the fridge bed for the front of the bed floor. I have not made it that far yet.
"The Iron Rhino"
-duraspark II/ HEI
