my 66 f100
fordtrux62
Re: my 66 f100
Post by fordtrux62 »
THE FITTINGS IN THE TRANS ARE 5/16 INVERTED FLARE I USE 2 6' PIECES OF STEEL LINE USE BENDER SO YOU DONT KINK THEN RUN SHORT RUBBER LINES TO COOLER YOU MAY WANT TO RUN UNIVERSAL TRANS FILTER IN LINE IN HOSE 79 AND UP FORD USED DEX MERC FLUID SO AT THIS POINT YOU CAN USE EIYHER DEX OR TYPE F BUT DONOT DONOT MIX THE TWO FLUIDS USE ONE OR THE OTHER DEX IS EVERY WEAR TYPE F IS BETTER BUT NOT EVERY WEAR AND IS HARD TO FIND ON THE ROAD
Michelle
Re: my 66 f100
Post by Michelle »
Did you have any trouble getting the C6 bell housing past the front cross member that is riveted in?
Michelle
66redrider
Re: my 66 f100
Post by 66redrider »
Michelle wrote:Did you have any trouble getting the C6 bell housing past the front cross member that is riveted in?
Yes i did.... i ended up having to take it out. Im sure if the motor was pulled and trans was installed as a whole it wouldnt have been an issue
Michelle
Re: my 66 f100
Post by Michelle »
I figured as much. I am getting ready to do the same thing. I kinda wish I had bought a FMX with a detachable bell housing. I think I could have made with that set up, but the C6 presented it self and I couldn't pass it up.
Michelle
66redrider
Re: my 66 f100
Michelle wrote:I figured as much. I am getting ready to do the same thing. I kinda wish I had bought a FMX with a detachable bell housing. I think I could have made with that set up, but the C6 presented it self and I couldn't pass it up.
yeah with a detachable bell housing like a c4 etc it would be no issue
66redrider
Re: my 66 f100
did alittle work today.... got the bench seat out and vacuumed out the floor in prep for the floor liner(fatmat) and also added a few hose brackets for the transmission lines to try and keep them neat
66redrider
Re: my 66 f100
Not much work but alittle more done... started the floor liner. Would say i got about 40% of it done
aarons428
Germany
Re: my 66 f100
Post by aarons428 »
Btw you need to move your trans cooler to Infront of your radiator or you might as well not run it at all. You do not want to heat up your trans cooler from the radiator heat!!!!!
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
66redrider
Re: my 66 f100
aarons428 wrote:Btw you need to move your trans cooler to Infront of your radiator or you might as well not run it at all. You do not want to heat up your trans cooler from the radiator heat!!!!!
Install instructions mentioned putting in between the rad and fan making sure there is about an inch between the fan and cooler
66redrider
Re: my 66 f100
Not much of an update but dropping my driveshaft to be done
aarons428
Germany
Re: my 66 f100
Post by aarons428 »
Trans coolers are NEVER to be placed behind the radiator!!! Trust me I do this for a living!! You never want your cooler to be heated you always want the fluid to be cooled as much as possible.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
66redrider
Re: my 66 f100
The driveshaft looks all pretty lol they did a nice job and it cleaned up nicely
66redrider
Re: my 66 f100
Carpet not quite done yet
66redrider
Re: my 66 f100
Anyone have any tips for installing the carpet, like best way to cut it to make it lay around the steering column etc?
Re: my 66 f100
Carpet looks good!
66redrideri just installed a carpet in mine. I cut a straight line north of the steering column and will use tape on the underside to hold it together when I'm done. You won't be able to see the cut when done.
Used a sharp razor knife and a scribe poking from below to locate holes.
66redrider
Re: my 66 f100
shipwrecked wrote:Carpet looks good!
any pictures? Installing carpet is new to me. I cut a slit down the center where it met the column but its the goong around it to lay it flat that has me questioning myself
66redrider
Re: my 66 f100
Carpet is fully in place, driveshaft is in but shifter is another issue. Was moving along with the install until i noticed a part on the shifter was riveted in place wrong so it will have to go back to be replaced
66redrider
Re: my 66 f100
Was wondering if I could get some help... where can I tap into for my shifters neutral safety switch and reverse switch? Thanks.
66redrider
Re: my 66 f100
66redrider wrote:Was wondering if I could get some help... where can I tap into for my shifters neutral safety switch and reverse switch? Thanks.
Anyone? Much appreciated for any assistance
Re: my 66 f100
I do not think these trucks came with the safety and reverse switches. They did not have backup lights. I do not recall what transmission you are using. Some c-6's came with the switch at the shift arm on the transmission itself. Most were on the column. You might want to take a look at later ford trucks and see how they did this.
