Shadow wrote:HawaiiKid wrote:Born and raised in Hawaii-went to school in upstate New York, moved home for a year and a couple years ago moved here to Ft Worth, Texas
What Island? I Spent 8-Months On Maui (Kihei-Beach) Doing Union Tile Work At The 4-Seasons Resort. Ended Up Moving To Kauai And Doing Marble & Tile At The Grand Hilton Kauai And Ended Up Staying For 6-Years When The Job Was Over Living In Hanalei. Right Now I'm Missing It! No Harsh Winters There On The North Shore Like Here In Kansas.
I lived on Oahu in Honolulu and spent a lot of time on Lanai also. Hanalei is beautiful, I like Kauai but it was a little too quiet for me haha. Winters, summers, springs, falls...what isn't nice in Hawaii!! I like having a change of seasons here but I hate the horribly hot summers in Texas. With that said I also love the cost of living and the car and truck culture here so I'll be staying for a while
therealjoeshmoe wrote:TAKE YOUR HOOD HINGE SPRINGS OFF AND WATCH YOUR HOOD SIT DOWN PERFECTLY.. JUST HAVE TO HAVE A PROP ROD, BUT CHEAPER THAN NEW HINGES..
I took your advice when you gave it to me a few months back in this thread actually, but the left part of the hood had actually been ripped out by the previous owner due to the screwed up hinge. I don't want to invest a lot of time in rewelding it and trying to make it look good when it has hail damage and rust in numerous places so I'll be making a wall ornament of it soon I think. For now it is behind our shop having more "patina" added to it haha.
For my update....
Our custom rockers! The steps had been totally rotted out, poorly replaced and then rotted again. Rather than screw with buying new steps and cutting half of them off we used 90 degree angle 3/16ths steel (WAY over kill but the only angle that was big enough for us), Dennis Carpenter rockers and Dennis Carpenter cab corners (all of which was totally destroyed on the truck). I still need to make a couple small patch panels to fill in the gaps and weld the cab corners on but I now have steps and rockers!!!!
The rocker is straight, the door...not so much haha
Our 72 Stepside that we are frame swapping to an 03 Crown Vic-no floor swap here, but it is still getting the full custom Farm Truck Racing treatment!
Another angle
The bed back on, drilled and mounted in the back...
Got back out there today and didn't take any pictures but got a lot done:
Got all of my grounds actually "grounded"-to this point I've had three vicegrips holding my main grounds to the frame! Now all of them are properly grounded and that seems to have fixed part of my hard starting/battery drain problem. I also went through my main fuse boxes and pulled everything I wasn't using so I would avoid any unnecessary drains on the system. Started to get the tail light harness sorted out so I'll have running lights, tail lights, brake lights and blinkers all ready to go soon. Got the front bed mount drilled and prepped to have the bed mounted and then we set the bed back to get the cab corners welded and mudded tomorrow. Test fitted a wheel I know has never been on an F100 or probably a Crown Vic ever before too...pictures to come if it all works out!
