Nicks 66 F100
Nicks 66 F100
Ok just so i can show my progress and maybe help with some guidance here are some pictures of the rig so far. keeping in mind i just bought it on 7-1-09
Nick
when i first brought it home.
Took the bed off to POR 15 the frame
Nick
1966 Ford F-100, Long Bed, Custom cab, 2wd, 352ci
- twistedfreak
Just saw a 390 motor for $300 bucks on craigslist. Search "f100" in the for sale area on Chicago site. It says it's locked up, but has an Edelbrock performer manifold on it. Who knows, it may have some other usable performance or dress-up parts too. It was in Merriville In., so it's not too far away.
Jerry D
Jerry D
Heres more pics of progress, just waiting on my buddys cherry picker so i can mount this motor on the engine stand. 2 bolts left and thats the motor mounts.
Heat valve
You go it right it's too speed engine warmup. You can get rid of it if you want, performance engines didn't use them.
- ezernut9mm
lmc sells those for around 85$. lol. chuck it.
Well pictures will be up soon, but I ripped out the driveline today, sat back down and thought about what's going to be put on this motor. Since I decided to keep it, and put a newer manual trans behind it. But this 352 is really not a performance motor huh? I really can't find upgraded parts for this yet. Maybe I'm just looking in all the wrong places. Can someone point me to the right direction?
Nick
Nick
If you are willing to do machine work, you can punch the 352 out to a 390 and then use all the bolt on goodies for that motor. The 352 was a blue-collar motor without much in the way of performance additives. If you aren't into the whole "boring" thing, Edlebrock does make a Performer RPM aluminum intake for it, it should be worth a lil horsepower and response, not to mention weight savings. That stock cast iron intake is a boat anchor. A set of headers and a Pertronics ignition would atleast give her a lil oomph, but you'ld probably be better served finding a good used 390 and go from there.
Just my 2 cents.
Greg
Just my 2 cents.
Greg
