Hi all,
I just purchased my first 65 F100 a few weeks ago and stumbled across your site. I've been finding it very informative and enjoy the friendly "feel".
I have a tremendous wind noise that seems to be coming from somewhere in the front dash area. It seems to kick in around 25 MPH and get louder as I get faster. I've checked all the firewall pass-through points (wire harness, heater hoses, speedo cable, steering column, etc) and don't see anything that looks like the problem. The cowl area is rust free (no holes or open seams that I can see).
Maybe the defroster grills or heating duct work ?
Any ideas on areas I can check ? What I really need to do is have my wife drive while I crawl around trying to get a better feel for where the noise is coming from.
Thanks for any suggestions.
John.
First post - wind noise coming thru dash ??
there are a couple acess panel covers you may want to check, one is in the center of the cowl below hood, then one on each side behind front fenders, theres a foam seal where the fender meets cab, air could get by there, also inside on kickpanels is fender bolt access hole.some have covers, some do not.air will come thru if no cover.
also you may want to check windshield and other chrome if you have it as a loose piece may whistle if air gets behind.
also read in the trivia post about the magic aire heaters and the plenum, anything in there will cause blockage and possible noise.
ClanCassidy wrote:are the cab mounts where the rubber pucks are that mount the cab to the frame i.e. body mounts ?
Yes.
Being a rust free truck, I'd double check your wing window areas...if the weatherstripping is dried enough, it won't seal air out very well anymore & could sound like it's coming from further forward.
Welcome aboard!
Hi John! Welcome to the club!
I see your In Brighton Michigan. I live over in Sterling Heights but my girlfriend lives in Howell.. Im there at least once a week, especially on the weekends. In fact, I just got back from there a few minutes ago. We drive into Brighton a lot to go to cracker barrell. Maybe we can get together sometime and do a cruise night in the spring or something. Have a good one!
Travis
1949 F-4 226/4 speed
1964 F100 223/3 speed
1965 F100 4x4 445/4 speed
