Are all 9" rears virtually the same?
northbayclay
Post by northbayclay »
Can I feel fairly confident swapping the pumpkins in my trucks? They are a '64 F100 and a '65 F100...both stock Ford 9".
I've heard talk of rear axles with different numbers of splines, but I imagine that has to do with 4X4's or heavier trucks.
Thanks for any help
Clay
Johnny Canuck
Post by Johnny Canuck »
All you ever wanted to know about 9" rear ends
http://www.kevinstang.com/Ninecase.htm
northbayclay
Thanks JC- I'll check it out.
Clay
Truckfarmer
Post by Truckfarmer »
The rears should be the same. Both should have 28 spline carriers. Ford went to 31 splines in trucks about 1973. Should be a simple swap.
Be sure the input yoke is the same. They are interchangable if you have to swap them. Becomes a pain to do as the yoke nut is torqued to 170 ft/lbs. If you remove the yoke, you should install a new "crush sleeve".
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
Just a short note that on 70-72 F-100 Ford Trucks did carry a 31 spline axle also so be on a watch on that too so 73 was not the first years of the 31 spline axles
12649
banjopicker66
Post by banjopicker66 »
Check the spline count for sure. I had a '70 F-100 with 31 spines.
