It's Bedtime
64low-n-slow
It's Bedtime
Post by 64low-n-slow »
Over the past 3 years I've done a bunch to this truck. Just now getting into the worst part, the bed. Until now haven't posted anything in Projects & Builds, but a lot of people, myself included, post questions about rust repairs, parts availability, etc. Must give credit to a few people in advance. First - Backyard Resto for doing the research to find an available bed floor panel that fits, second - Twistedfreak....you make metalwork look easy, and finally, everybody on this forum who shares such a great wealth of knowledge on these trucks.
Starting with a pic from the day I loaded the truck near Atlanta_Image
This truck was a great project, had been in the garage for 20 years. Cab was in great shape. I knew the inside of the bed might be a challenge, actually figured I could easily buy a clean bed for cheap (duh).
Here's a pic with the center of the floor cut out
64low-n-slow
Found a local sheet metal shop to bend up the 4 corner floor panels. Here they are along with the floor for trial fit. The floor panel I used was the correct width, but required some slight modification. First it is about 3 inches too long. Once I trimmed out the old front panel I got an exact measurement. I cut it using a straight edge and an air saw. Afterward I used 80 grit on a grinder to smooth the cut. The floor braces were different so I drilled out the spot welds and removed all 3, then moved the rear brace to the front to replace my original rusted out one. The second pic shows from the top where I welded it back on.
64low-n-slow
Last post for today, first pic is the front panel clamped into place. I cut off the top of the original front panel to reuse. It is rusted out in a few places but I'll patch it to retain as much of the original look as possible. A piece of square tubing would be an easier way to go.
A shot of inside the bed from the back. Spent this weekend sandblasting on the inside panels and mocking- up the floor and front panel. Nights when I am home this week I will finish prepping the inside for primer and finishing the hammer and dolly work to get ready for welding.
Left rear corner clamped in place .
very nice work !
36truck
Post by 36truck »
Loots of work doing that but you can't beat how it looks now. Great job.
Tom Williams
Max
Post by Max »
I agree, very nice! Will be sweet after it's painted. Don't forget to allow for drainage!
jwh f-100
Post by jwh f-100 »
X4 very nice!!!!
Jason
Beer will change the world.
I don't know how but it will.
Nice work.
tschmitt
Post by tschmitt »
Great job looks great!
Jim
Post by Jim »
I need to do the same for my 66, where did you buy the bed pannel?
thanks
Jim
1966 f-100 V-8, 3 on the floor, shorty
Power by Ford
Post by Power by Ford »
Looks very nice. What truck did the bed floor come from?
Love those SLICKS
ezernut9mm
Sweden
Post by ezernut9mm »
i wish i was that ambitious. lookin' good.
64low-n-slow
Thanks for the encouragement. I will add some drain holes into the corners before primer and paint for sure.
The bed panel is a factory Ford panel. It's an '08 F-250 4x4 6 1/2 foot replacement panel. Backyard resto has the part # listed on his build post.
kstones63
Post by kstones63 »
Looking good. It's good to see that we can get a bed floor that looks good in these trucks even though it wasn't made for them.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
64low-n-slow
I've been slackin' on the Slick. Worked the last 3 weekends so had to take a break. Should finish all the welding and grinding this weekend and get the underside primed. Will post pics Sun.
tschmitt
Post by tschmitt »
If you dont mind me asking could you tell me how much the bed floor cost? I may consider doing this to my bed as well and would like to have an idea financially how much this would cost me.
64low-n-slow
Including tax, just over $300. There is still a fair amount of spotweld drilling and trimming needed with the new panel because the braces are not in the right location. I just needed 1 NEW part to work with for clean, straight edges.
tschmitt
Post by tschmitt »
Thanks alot, im sure its going to turn out great.
64low-n-slow
Didn't make the progress I hoped for this weekend. Spent most of today fixing fence so my honey's horses can't run away (shame). Did get more welding done and shot a few pics. If anybody wants to come by and help.....
ezernut9mm
Sweden
lookin' good man. can't wait to see the finished pics.
