Can a couple of you help me out by checking the height of their stock frame as close to the front wheel centerline as possible?
I measured the height of the top of the frame directly in front of the front crossmember (the one under the engine) on my '65 at about 20.5 inches and would like to compare that to others.....
Thanks for the help!!!
stock frame height??
- slixtyfive
'65 2-wheel drive, right?
- slixtyfive
yes 2wd
Yes, 2 wheel drive is correct. I should have clarified that up front.
Thanks,
Thanks,
