Guys, it's been quite a while. But Saturday, 3/28/15 I fired up the 351C. I got the oil pump primed, gas siphoned to the pump, and filled the float bowls with gas too. My friend, who was there for support, was very startled when the thing lit up the instant I hit the key! It's pretty loud with purple hornies and side exits in front of the rear tires.
Now I am working on sanding and painting the door jams and the door edges. I've got new seals and I have found a place to install the windshield for $220 - that includes the glass, but I'm providing the gasket. Windshield is $150, so $70 to install it???? Hell yeah!
So, doors, windshield, then front end sheetmetal and I can drive it!
'62 Unibody Build (back) Up
- Gary Seymour
Re: '62 Unibody Build (back) Up
And the weather there should be getting good enough to take it for a drive.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
Just read the entire thread.. Fun read, you're a good writer.
Keep the updates coming!
Randall
Randall
- Gary Seymour
Thanks Kevin and Randal,
Yes the weather is really decent here. I got one door jam painted and one door edge sanded. Also adjusted the neutral safety switch on my Lokar shifter.
I should get the rubber stuff in the mail tomorrow and schedule the windshield.
nice job on the bed floor patch
wherever can you find those at
seriously very glad to see you near the end of the long project
- Gary Seymour
Those bed patches came from the rust-free zone of the arctic circle!
I have some left over. I wonder if I can get a rebate??
- Gary Seymour
- Gary Seymour
Today was highly productive. I started by putting on the new hood to cowl seal.
There is a separate post on this subject in Truck Talk.
I hung the right door - the jambs and opening was painted and a new door seal put on. Before I removed the doors, I drilled a small hole through the hinges into the jamb to help alignment when putting them back on.
I then painted the left door opening.
Then I glued the left door weatherstrip on. I learned to run masking tape along the outside edge to keep from making a total mess with the 3M Super Black adhesive. I saw a rep. from Steel Rubber on My Classic Car demonstrate how to apply the cement. Spread out a small bead on both parts, let get tacky, then spread another small bead on the rubber and you better have in in the right place!!
More to come
More to come
Gary,
Nice work on the Uni and thanks for taking the time to document your saga. One question (and I hope I just didn't miss it in reading). What did you use for the front sway bar?
- Gary Seymour
Fortyboy, sorry I have not checked this in a while.......
I think the front sway bar is from a mid-seventies Ford truck. I got the sway bar info (including the rear - which is from some sports car I think) from a post on this site.
