I've got a 1965 F-100. Gearbox needs work anyways so i'm contemplating a power steering upgrade. What's the community's widely accepted kludge for a power steering conversion on this year?
*i'm still a little new to this so feel free to point out pertinent info i've left out =D*
Power Steering?
- banjopicker66
Lightshow, this is probably the second easiest upgrade, the first being power disc brakes.
For both, your best bet to save a whole lot of time and frustration, is to get a '73 - '79 truck as a donor truck.
To upgrade to power steering, you will need:
PS gearbox with Pitman arm
PS pump, hoses and a cooler
Engine brackets and pulleys
A '70 - '79 PS steering column, with the PS firewall support bracket - these are needed because the PS gearbox is about 2 inches shorter than the manual gearbox.
You may hear references to a Bendix system - it will bolt up, but the system is not as good or long-lived as the Ford one. Ford abandoned it in '68 or '69, only using it for 2 or 3 years.
If you want power disc brakes, the donor truck you choose should have them - it will have all the parts you need to use, or for cores.
And, if you want to change the drivetrain, as in from stick shift to automatic, you can do this also more easily if your donor truck has all the comfort options you want.
- 65 66 Ford
The PS gearbox is about two inches longer than the manual gearbox.banjopicker66 wrote:Lightshow, this is probably the second easiest upgrade, the first being power disc brakes.
Fran
65 Ford F100 CC style side looooongbedddddd
Be American buy American
