Cant Kill a Y-Block....
- f100fordguy
Pulled motor today and found out where my loss of compression was in the 292. Am very glad it stayed together during slickstock as my bad piston came out in pieces Took a pic for you guys to see how bad I killed it. Next slickstock she will be bigger and badder and might even be able to drive it there!
http://www.fordtruk.com/forums/album_pi ... &user_id=7
Tim
Tim
Gotta love them y blocks
resurrect the old girl I say
- 64low-n-slow
- f100fordguy
- ezernut9mm
damn tim, i'd say that'd let some compression out.
You beat me to it .
Lowell's correct! Remember it's a Y-Block not an FE. JB Weld it, put it back in and you should be good for another 100,000 miles.
- charliemccraney
f100fordguy wrote:as of right now its .060 over. unsure if it origionally was a 272 or 292 now but gunna go to at least a 312 std bore and get a isky cam and put big valve heads in it. Im still debating throwing msd in it, all depends on budget this winter but should be a really strong runner once i get done.
.060 0ver 292 is .010 0ver 312. At that size, sonic testing will be wise, even with a Y block, and particularly if it is a C2AE block.
A good alternative to MSD, if you plan to use a box, is to convert to a Duraspark trigger. It's basically what MSD uses anyway, and much cheaper. If it's not something you want to do yourself, Performance Distributors can provide a Durapark distributor, custom curved, to fit your engine. The biggest downside to the Duraspark route is that you must use a box, while the MSD does not require a box.
- charliemccraney
kjvforme wrote:What about sleeving the block back down to 292?
Not cost effective. In my area, to sleeve 8 cylinders is about $1200. You can buy 4 or 5 engines for that and find a good one to rebuild easily.
One time I was doing a burnout, and suddenly the rear end blew up, and the 292 went straight to the moon. I saw the RPM needle rocket to 8k and drop back down!
It didn't even cough. It's a stock 200k motor that's the only thing on the truck that's never given me any trouble.
Yep, you can't kill a y-block.
Just driving my truck.
