oil passage on a 64 292
LRS30
Post by LRS30 »
I removed the valve covers did a valve adjustment, started it up and notice oil only climbing up the push rods, Should it also be coming out of the bent tubes aiming at the rocker assembly, It seems that it should. What is the best way to clean out this passage,is it realatively easy to remove the rocker assembly and soak to clean everything else there? It is realativly clean, but the no oil thing has me worried....
jjim7
Post by jjim7 »
Check out "Y Blocks Forever". Everything you want to know and more. :wink:
Jim
Mild Mitch
Post by Mild Mitch »
I'm no expert, but this is a little of what I've learned and found out about the Wonderful Y Block.
First, it's pretty straight forward to pull the oil tubes and clean them. Also you may want to clean all the oil passages you can get to. Most of the engines form this era are pretty gummed up. Mostly form inattentive owners and the oils available in the '50s and early '60s.
Oil that was spec'd for the Y Block was straight 20wt, Yeah, 20wt.
Kept the oil moving thru the engine. AND, kept the top end oiled.
With that said, I have had a tough time finding straight 20wt these days and with my new rebuilt 292, have gone to 20-50.
Mitch
"your mileage may vary"
Mild Mitch
Mitchell Motor Works
Anderson, California
1962 F250 Uni
2000 F100 Lightning
1951 F5 car hauler project
1931 Ford Roadster
LRS30
Post by LRS30 »
THANKS GUYS YOU ROCK!
