Me and My 66 Slick Made it home
TX, OK, AZ, LA, NM, AR, CO
Old_Ford_Man
Post by Old_Ford_Man »
Well I made it home with no troubles, I went to Oklahoma to spend Christmas with the in-laws and from their house go to Grandview, MO and pickup my 1966 F-100 Custom Cab. I drove from Grandview, MO to Pawhuska, OK. I was there 3 days to give the Slick a good looking over then drove it from Pawhuska, OK back to Huffman, TX. Here are a couple of pictures I took when I got home and washed the road dirt off
1962 Ford Fairlane
1966 F-100
Casey 65
Post by Casey 65 »
When you were in Grandview you should have given me and Ezer a call, We would met you for coffee (or something... LOL)
P.S. I really like your truck! :thumright:
Old_Ford_Man
Wish I would have known I would have. The wife wants to go to Independence, KS to see the Arabia Steamboat museum so when I am up that way I will give you a call.
1962 Ford Fairlane
1966 F-100
slickmainer
Post by slickmainer »
looks like a solid truck.
--Gregg--
you can't get there from here
BigMike
Post by BigMike »
Looks really nice. What are the specs?
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
Old_Ford_Man
Thanks she is all factory except for the headers, cherry bombs and back bumper. :D
1966 Ford F-100: second year of the "Twin I-Beam" front suspension system where the two front axles work independently to absorb road shocks. It also holds wheel alignment which reduces tire wear. In combination with the new Flex-O-Matic rear suspension which adjusts spring stiffness.
F100 - 1/2 Ton
Wheelbase: 115 in / 129 in.
GVW 4x2: 4,200 - 5,000 lbs
Tires: 7.75 x 15
Engine: 352 cid 8 cylinder
Transmission: 4 on the floor with First gear Garnny
Assembly Plant: Kansas City, KS.
1962 Ford Fairlane
1966 F-100
BigMike
Post by BigMike »
What is the ratio of the rear end and what kind of mileage did you get on your trip?
I have the same eng/trans w/ a 4.10 and get about 10.2 on the road cruising 67mph
Old_Ford_Man
Same setup and yea about the same gas milage I think. On the trip back I had a bad head wind and the speedo is not working so can not say for sure, but when I get it fixed I will get a more accurate number and will let you know.
1962 Ford Fairlane
1966 F-100
Old_Ford_Man
Well I got the shocks installed the Saturday and installed the vent hose under the dash Sunday and spent another 3 hours trying to revive the old faded paint. I have to say it is looking better it is just going to take time.
1962 Ford Fairlane
1966 F-100
Old_Ford_Man
Dash Panel Restoration Project
Well my dash panel restoration project is complete, I will add the picture when I get it installed.
[albumimg]8983[/albumimg]
1962 Ford Fairlane
1966 F-100
Old_Ford_Man
I got the dash panel back in and everything working.
[albumimg]9035[/albumimg]
1962 Ford Fairlane
1966 F-100
66Bullitt
Post by 66Bullitt »
truck looks very nice and solid!
Old_Ford_Man
Carpet Installation Project Complete.
I completed my carpet installation project, I know it is not that hard to install carpet in a truck but I think it turned out nice and I took my time and did it right.
Removed Rubber Flooring.
[albumimg]9038[/albumimg]
After Cleaning Inside and getting rid of 45 years of dirt and grime.
[albumimg]9039[/albumimg]
Installed Sound Deadening Material.
[albumimg]9040[/albumimg]
Installed Carpet Pad With Heat Shield.
[albumimg]9041[/albumimg]
Installed Carpet
[albumimg]9042[/albumimg]
[albumimg]9043[/albumimg]
1962 Ford Fairlane
1966 F-100
Old_Ford_Man
Installed a new shifter in my slick.
I installed a new pistol grip shifter in my slick it is a Texas thing, well it was more of a I have never seen one like that be for and it will look cool in my truck thing.
1962 Ford Fairlane
1966 F-100
