Sully's 1964 Project
sully5
Post by sully5 »
sully5
Post by sully5 »
Progress. Sorry for the crappy cell phone pictures.
Hookedtrout
Post by Hookedtrout »
That is going to be one awesome truck when you get it all finished. Great job!!
Cory
1962 F100 SWB Unibody, 223
1931 Ford 5 window coupe
Post by Gritsngumbo »
Pictures look fine. Truck's looking great! I envy you your lift.
MadMaxetc
Post by MadMaxetc »
That is looking realy good man. I can't wait until I am to that point.[/list]
My Build Thread
sully5
Post by sully5 »
She came home this week.
sully5
Post by sully5 »
Working on the cluster:
Inner fenders, core support, and radiator in.
sully5
Post by sully5 »
Didn't like the polished gauge bezel. It got smudges and fingerprints on it if you even pointed your finger at it. So I converted it to a machine-turned finish. Looks better and doesn't show fingerprints. Also makes the gauges look nicer.
8) Nice job on the dash panel!, did you do it yourself?
sully5
Post by sully5 »
Yeah, I made my own hillbilly engineering machine turning fixture. Hint: it involves a drill press and scotchbrite. :wink:
sully5
Post by sully5 »
Wanted billet door sill plates. Too pricey for me at this point, so I went down to the local fabrication shop with some poster board templates and they made me a set for $50 total. Also I was concerned about slippery door steps and scratched up paint in the step area. A little grip tape solved this dilemna.
sully5
Post by sully5 »
Redneck custom dash knobs! At least they match the paint scheme.
sully5
Post by sully5 »
Console, shifter, stereo installed and wired.
slickmainer
Post by slickmainer »
good call on the console. I did that in a 66 I had years ago. saved the dash, installed all the crap I wanted in the wood and then just used the AM radio screw hole in the dash to hold it all in place. take it out when I sold it...back to stock in 1 minute
--Gregg--
you can't get there from here
sully5
Post by sully5 »
Yep. There was a hacked radio hole in the dash when I got it. The PO had made a wooden block spacer because modern stereos are too deep. Welded up the hole for a nice smooth look and put it all in the console. Shifter is a modified late model mustang unit for AOD and an early mustang bezel. Cup holders are poker table stainless cup/chip holders. Vents are billet specialty for future A/C installation, and the stereo is a $100 Sony. I almost forgot a 12v socket for cell phone chargers etc. Added it last.
Robert
Post by Robert »
Sully this is a super nice build can't wait to see it done
sully5
Re: New Guy 1964 Project
Post by sully5 »
Ok, been awhile.
Engine compartment is nearly done. Having some pulley alignment problems, but nothing major. Yellow seems to be a theme here. :shock:
I fabbed my own throttle linkage using a modified original pedal The linkage rod has RH threads on one end and LH threads on the other. That wat I can turn the hex section with a wrench and lengthen or shorten the linkage as needed.Image
sully5
Post by sully5 »
I moved the booster/master cylinder over to the clutch side to give me lots of room if I ever go big block.
To make sure the brake pedal was close enough to the gas pedal, I modified and lengthened the brake pedal arm and made a wide footprint pedal with a late model pedal cover on it. The perspective of this photo, makes the brake pedal look real low, but it's not. It's about an inch lower than original. I had to ad the inch to make sure the foot wouldn't hit the column.
sully5
Post by sully5 »
Installed a Ford Taurus electric fan.
1965fordf100
Re: Sully's 1964 Project
Post by 1965fordf100 »
Nice work! When do you plan on having her on the road again? Yellow is one of my favorite colors, keep the theme going!
Phil
