Can someone tell me if a 64 f100 steering wheel will fit a 72 f100 steering column??? Or if there will have to be major fabricating.
Thanks!
64 f100 steering wheel on a 72 f100 steering column???
from my understanding Tigger, the nub on the top of the splined shaft will have to be cut off.... I am not sure of this because I am using the later steering wheel but I am almost positive that we discussed this in a topic on here... others will chime in to help I am sure... not to bad if that is all you have to do....
