HELP Axle pivot bushings
66Rat
Post by 66Rat »
I'm trying to put axle pivot bushings in my truck and I can't get them to go in strait. I used a balljoint press it got the old one out fine but I can't get the new one it strait it just binds up.
64 f100
Post by 64 f100 »
Those suckers are tricky. I used an althread rod that would fit thru it, and pulled the bushings in with large washers. Problem I ran into was the bushing sticks thru and I have to find a bearingg race that out fit over the metal of the bushing so it would presson thru the i-beam.Not easy to keep center up. I'm not certain but I think I welded a washer to watever I used. Could have bee a little section of pipe I squashed to make oval, and di this all with an impact. Rough on the althread though.
Moose
Post by Moose »
What kind of bushings are you going with? Rubber or Poly?
You really need to use a little bit of grease on a poly bushing to keep it from squeaking. Also helps things go together much easier.
Moose
American born, German blood, Texan attitude..... And people wonder why they call me "Moose."
66 F-100 Too much to list
05 F250 The Tank
66Rat
Post by 66Rat »
They are rubber and I still used grease. I tried using a bolt and nut with a washer for some reason I can't get them to stay strait.
MadMaxetc
Post by MadMaxetc »
I used my 5ton shop press, and even that took a lot of effort.
My Build Thread
