[albumimg]8978[/albumimg]
How she looks now. doesnt look like much. i built it to be the AK-47 of slicks. simple, no frills, and reliable.
[albumimg]8979[/albumimg]
Engine as it sits now. the pot I had over the carb became the air cleaner cover. You can also see the bellcrank throttle linkage.
[albumimg]8981[/albumimg]
Another engine picture. Choke tube runs along the top of the exhaust manifold and then goes to the air cleaner.
[albumimg]8980[/albumimg]
battery tie downs. the wood is 3/4 cabinet plywood.
[albumimg]8982[/albumimg]
duraspark/ hei. the module is mounted on a computer heat sink.
Finished!!! my 63 wrongbed with 300-6 transplant
- bobenhotep
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
- bobenhotep
do not, i say again, do not reverse the pickup wires. it will not run, but it will have spark, and it will confuse the heck out of you.
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
- bobenhotep
Basic list of stuff on the truck.
electrical
-electric fan
-delco 3 wire alternator
-duraspark HEI ignition
fuel system-
-1 bbl carb for 1970 f100/ 300-6
-atwood marine fuel water separator
power/drive train-
-1980 300 6 cyl, synthetic oil, 195 degree thermostat
-11 inch clutch
-wide ration 3 speed toploader with good column shift
-2.70 ratio 9 inch rear end.
electrical
-electric fan
fuel system-
power/drive train-
-11 inch clutch
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
