tranny question
jeffw
tranny question
hey guys,, I had a trip recently with my slick, the ol three speed,,with the 223,, the engine was revved up at 60mph,, sooo I was wounderin if there is such thing as a tranny out there with four to five gears that would work on a 223?? you know, make the trip more friendly on the motor,,
Tranny
blackagatha
a tighter gear ratio will help top end, but will be sluggish on takeoff- a large ratio will give effect of more torque on takeoff, but worse at top speed. I imagine you know this...
I wish I had an overdrive for my 390. An overdrive is definitely the way to go if you can find one.
They made and installed on our slicks an o/d trans. bolts to our bell housings and used the same clutch. the catch is finding one. If they wind up on evilbay they go for big bucks. I found one and im waiting on the yard to dry enough to go pull it. When I install it ill replace the clutch for the fun of it but I will need to shorten my drive shaft. Which is okay because it vibrates anyway. By the way mines a 223/3spd on 392's and your right it screams at 60.
US Navy AT3 Desert Shield/Storm. EA6Bs out of Whidbey Island WA. With Carrier Air Group 3 off of the soon to be retired USS John F Kennedy CV67
- adrianspeeder
No, not much at all, except that it has 6 cylinders and the are in a row.
Pardon the SA response. I don't really know -- the 240/300 use a standard SBF bell housing, which means you can drop pretty much anything behind them. I don't know what can and cannot be done with a 223.
I do know that the 223 did come with t-98 Warner 4 speed, which is a truck tranny (much heavier duty than the 3 speed), but the 4 speed t-98 is really just a 3 speed with a very low "underdrive" as first and 2-4 quite similar to your 3 speed.
There is a similar t-19 tranny that will bolt to any housing that ever had a t-98, so would go behind a 223. The t-19 can be had in a so called "close ratio" -- and that, coupled with some higher rear end gears makes for a good driver.
BUT, it seems close ration t-19 trannies are hard to find.
So back to other options. I wonder if an OD toploader unit could be found that would bolt up to some sort of223 bell (or did toploaders have an integral bell?)
Frankly, a lot of folks would ditch the 223 as well if they didn't like the driving experience. Not to run the 223 down, but its not nearly the engine that the later V8 or even 240/300 engines were.....
- Truckfarmer
Friends of mine from Wisconsin adapted a Mustang T-5 to a 223 and also to a 292 Y-block. They documented it on the tech section at the Badgerland F100's website,, http://www.badgerlandf100s.com/
Truckrat rode in the 61 Uni with the 292 and S-10 T-5.
- bobenhotep
i have pondered this also. i have a 3 spd from a bumpside that i was going to use, but it is overall about 2 inches longer, and the input is shorter. might still work. the bump tranny has like a 2.99 first gear, and the one in the truck is like a 2.5. if i had a lower first gear, i could go with a higher rear gear and take off the same. the 223 has a fairly wide powerband so it can handle the wide ratios. if not, i can make it handle the wide ratios...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
This place modifies belhousings accept T-5 OD trannys. Use the S-10 tailshaft though. http://www.ford-y-block.com/truckt5.htm
fmartin_gila
Tranny Info
I run a T5 in my 62. John Mummert at the y block website in the earlier post can set you up with what you need (PP,Disk,TO,Pilot & adapter), you still would need a tranny from a 94-95 Mustang to do this. Cost was 425 a few years ago when I did mine. You will also need a shorter driveshaft. Let me know if you need more info, I am very well satisfied with mine.
Fred
Fred
64slick
There is darn little that is interchangeable from a 223 and 240.
Now, in many circumstances, the same tranny can be installed on either egine, but only if you can find a bell housing that is correct.
Thus, I was trying to say that a 223 that had a bell housing for a T-98 would also be able to take a t-18 or a t-19 since the have the same tranny bolt pattern. But as to what other trannies can be made to work with the right bell housing, that I am of no help....
Sorry.....
Sorry.....
shawns fords
