Looked at the vin decoder and tried searching but did not see 'N' listed at all. Thanks in advance.
Mrgoob.
Old eyes in the dark. It is M-thanks.
Paint code N? Sorry everyone- it is an M
M = Wimbledon white for '64 and newer. Before that, M = Corinthian whiteBill W wrote:M = Wimbledon white.
At least that's true for the Ford cars. I assume it's the same for the trucks. I don't know why Ford kept the same "M" code when they changed the color of white between '63 & '64. It caused me huge problems with a 64 Galaxie I restored one time. The painter went to purchase the paint but forgot if the car was a 63 or 64. The book showed the same "M" code for both years. They mixed up the 63 M code paint and it was wrong. Further research showed the white for 63 was Corinthian, which is a dirtier white, less creamy. The painter found this out too late and had to repaint the car with the correct '64 Wimbledon white.
I just found this link which confirms what I said above. '63 was Corinthian white. '64 is Wimbledon white. Both use the "M" code.
http://www.classictruckshop.com/photopo ... hp/cat/527
It may look the same on the chip, but trust me, it's not the same color of white!
