Hood Adjustment
sixty6
Hood Adjustment
Post by sixty6 »
Tips for hood adjustment. I have it mounted as low as the hinges will allow and the back of the hood will not sit down on the fender or cab.
Are the hinges sprung?
Bill W
Post by Bill W »
put some flat washers (1, 2 or 3)between the hinge and hood front bolt location.... dont ask me how but this will bring the back of the hood down.
GDG
Post by GDG »
The hinge pins are probably worn allowing the springs to pull the hood up when closed. New or rebuilt hinges is the best fix.
Doug
Dirky
Post by Dirky »
I was trying to work out the same problem this morning. Moved the hinge down as as far as I could, but still need more. Good to know!
Derek.
1966 Mercury M-100
tomrooster
Post by tomrooster »
If you grind the bottom 1/4" off the hinge it will allow it to go down a little . It was enough for my hood along with the washer trick. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
Dirky
Post by Dirky »
My hinges don't appear to be worn, but I would need to remove the hood and springs to determine that... Only one side of my hood has raised above the cowl... Probably 1/4" inch!
1966 Mercury M-100
Can you post a few pic`s so we can see what you mean?
Hawkrod
Post by Hawkrod »
It may seem counter intuitive but try and adjust the hinges up. They over center and drop a bit when closed and if the hinge is too low it does not do that and the back sits up too high. If the nose of the truck runs uphill all bets are off but otherwise adjusting the hinges up often solves the problem. Hawkrod
sixty6
Post by sixty6 »
Ezer- now that you mention that, it had a stack of 3-4 washers on each bolt when I took it apart. I didnt think it would have made a difference that I didnt put them back in.
sixty6
Post by sixty6 »
Ezer- now that you mention that, it had a stack of 3-4 washers on each bolt when I took it apart. Of course I thought the previous owner was clueless and thought those washers were unnecessary.
Alan- I will try and get some pics tonight.
At least the new Goodyears look good on the old pickup.
sixty6
Post by sixty6 »
This is what it looks like Alan.
Hawkrod
Post by Hawkrod »
You've got a whole mess of trouble there. Your fender is way out of whack to the cab and you will never get the hood to fit until the fender alignment is fixed. Note the gap between the cowl and fender is wider at the back and the door to fender gap is wider at the bottom. This is because the nose is too high. It can be caused by bad cab mounts or getting nerfed up front but untill the nose goes down the hood will never fit. Hawkrod
sixty6
Post by sixty6 »
Thanks for the heads up. I will see if I can drop the front of the fenders. The cab mounts are brand new.
Will be trying the washer trick first.
If you think that is a mess, I wont show you the rest of the truck...
What Hawkrod said is what I was looking for in the pic!, are the rubbers new under the cab mounts and the radiator support?
sixty6
Post by sixty6 »
Both are new.
sgart80
Post by sgart80 »
Hey sixty6, I'm having the same trouble with my cab lining up with my fenders. I also have new rubber cab mounts and radiator mounts. When I received my cab mounts in the mail, it looked like the rear ones were way to tall, but I installed them anyways. I don't know if that's the case and I don't have a solution to the problem yet, but I'm in the same boat, either the front of my cab needs to come up an inch, or the back of the cab needs to drop some, or the radiator needs to drop some.
There are a some threads on the board already that cover this topic, but you have to do some searching, I turned up these results when I searched for cab mounts, support, etc. I'm sure there are more threads on this subject somewhere.
http://fordtruk.com/forums/viewtopic.ph ... sure+mount
http://fordtruk.com/forums/viewtopic.ph ... ab+support
sixty6
Post by sixty6 »
Sgart- Thanks for the links. All of the cab mounts look to be the same thickness. With the exception of the radiator support mounts. Those are "homemade" and will be the first place I look for some adjustment.
Brians1966
Post by Brians1966 »
Thanks Bill W - Just re found this thread- been fighting a hood alignment bang.gif issue for awhile- took your advice- used a 1/8 inch fender/body shim at each hinge and woohoo.gif perfect - it brought it down level with the cowl worship.gif worship.gif thank you thank you
Brian
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
andgott
Post by andgott »
Wow- It works!!
I had all but given up on getting my hood aligned properly- Or even close. I figured I'd need new hinges- It was about 1/2" off-
But, I tried the shim 'trick'. I shimmed the front bolt on the hinge about 1/4", and Voila-
I realize it's not PERFECT, but it looks a lot beter than it did before, and it doesn't rattle nearly as much. When I get the new bumpers on there, it should be even quieter! Looks like I can hold off on the new hinges for a while.
William-in-St George
Cab Mounts
Really easy to overtighten the cab mount bolts and squeeze the biscut. Try loosening the front bolts a few turns and tighten the rear ones. After the cab is sorted out the fenders and core support can be adjusted. Sometimes these hoods will be flared out at the hinge from coming open at speed. Sometimes they will have cracks in the inner support near the hinge. You can squeeze them into shape with a ratchet strap and then use body glue to attach the inner hood support to the outer sheet metal.
William-in-St. George
