My 1965 ford f100
Re: My 1965 ford f100
It looks like you are making good progress. Nice work
- therealjoeshmoe
- therealjoeshmoe
OK, FRONT HUBS ARE DONE RIGHT THIS TIME.. STARTING BUILDING MY BRAKE LINES NOW. THIS SHOULD BE FUN.. HOPEFULLY WILL HAVE MOST OF THE BRAKE LINES RUN THIS WEEKEND.. THEN I CAN START PUTTING MOTOR AND TRANNY BACK IN..
- therealjoeshmoe
- therealjoeshmoe
WELL WORKED ON PUTTING SOME MORE SUSPENSION TOGETHER.. PUT NEW REAR AXLE OUTER SEALS. CLEANED UP THE REAR AXLES AND INSTALLED THEM. BOLTED ON THE STEERING BOX AND CLEANED UP THE TIE RODS AND DRAG LINK AND PAINTED THEM SATIN BLACK, AND GOT THEM INSTALLED. MADE THE REAR HYDROLIC BRAKE LINE AND INSTALLED.. AND OF COURSE INSTALLED NEW RED GABRIEL SHOCKS AT ALL 4 CORNERS.. ALL IN ALL HAD A GOOD WEEKEND!!
- therealjoeshmoe
- 1965fordf100
- therealjoeshmoe
welp more progress this weekend, i got the motor and tranny cleaned and put back into the truck,
sand blasted headers and painted with 2,000 degree paint.. prolly wont last long but it looks good now lol\
cleaned up the motor a little got it ready to paint
got it painted ford blue and yes i painted my streetmaster edelbrock intake lol i like it!
got the tranny all bolted up..
motor is in!! yay! lol
headers fit really good!
another 352 i got for my rat rod project after i get my 65 done!
I may have missed it, but what headers are those? Looks like you didnt have any problem with clearance issues on the starter, etc.
66 Layin Low
- therealjoeshmoe
oh they are close to the starter alright.. im thinking about putting the stock manifolds back on.. lol not sure what brand headers they are but they do fit really well.. im just afraid its gonna heat my starter up and kill it.. well guess i could always push start it... lol
- therealjoeshmoe
ok i went ahead and put the stock manifolds back on, gonna save the headers for a future project.. and got my motor al put together and ryno'ed my core support all while battling bronchitis this weekend.. what fun but i was gonna get something accomplished... so while yall goons were out playing this weekend i was getting stuff done lol
Awesome Build!!! I cant wait to get going on my 66 and looking over your build gave me a better idea of what im going to have to do with my cab.
For what it is worth. We put a smaller high torque starter on my sons big block cougar with no room by starter. Made a huge difference. Even with the battery in the trunk and loong battery cables we were able to advance the timing five degrees with no kick back hot,
1966 F100 240 3speed
- therealjoeshmoe
- therealjoeshmoe
well got some goodies for my birthday sunday.. got a new chrome dash bezel and a new clutch rod and bushings, i was pretty happy! lol
i got a bunch of junk bolts and stuff from work and there were two of these in a bag with some bolts... i have no clue what they really are but they fit my gas tank neck perfectly! lol
- therealjoeshmoe
- therealjoeshmoe
ok slixtyfive i guess you were right on the i beams, i still dont understand how they were working before.. but i got the driverside to sit right but the passenger side is way off.. anyway i found a good set of un bent stock beams ive got to sand blast prime and ryno, and replace the bushings.. well i guess in the long run it will be worth it!
NO I TOLD YOU SO's lol
- slixtyfive
Definitely not (on the 'I told ya so'). Just looking out for each other and trying to help here!
Keep up the good work and making progress.
- therealjoeshmoe
well got my 2nd set of I-beams (and hopefully my last) all cleaned up and I installed new pivot bushings from moog.. man all i can say is i was sure glad i bought a new air chisel.. it peeled them baby's right out.. used my 20 ton press to push the news ones right in.. very easy.. got the beams primed and bedliner sprayed.. little bit at a time... hopefully next weekend ill have them put in the truck..
- therealjoeshmoe
