brake problems on the 59
ebentraywick
Post by ebentraywick »
okay guys i have problems with my brakes they where working great for a couple of days. what i hade was a 85 elcamino brake booster. with a 77 ford highboy master c. well that worked great untill the other day it got hard as a rock. so i check my vacum pump workin great. so i bought a 67 chevy brake bosster with master c. its was cheap and its still not workin its rock hard any ideas????? thanks eben
o the drivetrain is a 77 ford highboy
owning a slick.,,, priceless :)
1961 ford f350
1959 ford f100. not a slick but still goood looking
]Image
Anthony
Post by Anthony »
rubber brake lines collapsing??? just a guess Eban..
64crew4x4
Post by 64crew4x4 »
With all the Swapping you have done...Have you done a COMPLETE SYSTEM BLEEDING....?
Start at Passenger rear and Bleed at least 1/2 qt of Fluid...Then go Drivers Rear, then Pass. Front then Driver Front...
When you are doing the Passenger Rear Bleed, you should bleed till you get GOOD CLEAN CLEAR Fluid....
Also, You might crack the lines at the Purportioning Valve.. And gravity bleed that a bit before doing full system bleed...
Is your 59 a Standard Cab...?
I just picked up a Super Cab 59...:)~
Good Luck , and Keep us posted...
Stable of Trucks.....
61 3/4 ton 4x4..312v8,4speed Daily driver.
64 1/2ton C.C. 292v8,3sp,...???? 82k orig.miles
65 1/2ton flareside parts truck
64 1/2ton Flareside currently 4x4.going to be 472 powered Gasser
65 SuperCab/Crewcab Cummins 1 ton Duelly Hi-Boy Project
