GLASS ATTACHMENT
Posted: October 19, 2011, 9:45 am
by DIXONBOY
Whats the best way to atach to door glass to the roller bar on the bottom. It came loose and I thought about using urathane glue.
Posted: October 19, 2011, 11:20 am
by Uncle Skip
Dixon. There is a special tape that you can get from an auto glass shop.
Urethane glue won't hold the glass.
Posted: October 19, 2011, 1:24 pm
by jamesdfo
Back in my bodyshop days, we called it channel pack (tape), it comes in various widths & thicknesses.....urethane will actually work, but should you break a window at some later date, you will probably spend more time trying to remove the remnants of glass & get the remaining urethane off than it would take you to earn the money for a new channel:):)
here is one hit I found off a quick google search....
http://www.hotrodders.com/forum/setting ... 46974.html
http://www.crlaurence.com/apps/sitesear ... ubber+tape
**tape is not adhesive, you fold it over the bottom edge of glass, set channel over tape, stand glass up on a nice clean 2x4, and knock channel down onto glass with a rubber mallet or dead blow hammer....tape needs to be thick enough to create an interference fit, as that is what holds the glass into the channel.....
James
Posted: October 19, 2011, 2:58 pm
by DIXONBOY
Thanls for the help. I work at a ford dealer so ill go to the bodyshop to se what they got.
Posted: October 19, 2011, 3:40 pm
by Uncle Skip
Dixon.
Have you hooked up with all the guys in North Texas?
Posted: October 19, 2011, 3:42 pm
by DIXONBOY
Who are they I would like to.
Posted: October 19, 2011, 6:26 pm
by 557f1
Divon Boy ,
this is a good question as I'm just about to do the same job.
Darren
