What have you done to your slick today??
Harper
Post by Harper »
lacking motivation, is key to NOT doing or acomplishing anything on our slicks....there fore...I started this thread, to hopefully motivate some who need motivation, (as well as myself) it does not have to be anything HUGE, it can be a simple "i changed my slicks oil" or "I washed my slick", I hope the moderators do not mind....with that said.
WHAT have you done to your slick today?
kstones63
Re: What have you done to your slick today??
Post by kstones63 »
I changed the throttle position sensor today. The torque converter was locking and unlocking at random. The shop manual says that this can be the problem otherwise I have to take it back to the tranny guy to get it checked out.
Now I need to go drive it and see if it fixed the problem.
Not much motivation but I did something.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
Well, started laying out the splash pan for the longbed, block-sanded all the white on the two-tone, chased to LKQ to find drip rails and mo' bumpers- no luck on either; dug out the replacement window components, then read the forum and found the name of the one-piece window kit supplier. I also crawled under the 65 shorty to determine the angularity of the tie rods in answer to a post here. Then I determined the "cut lines" for the BBW conversion on the red uni, and purchased replacement "combo chains" for the tow truck. Lots of motivation; Ol' Marais in ten days, Cruisin' the Coast coming up next month, then Houston Autorama, never a dull moment!
foodstick
Post by foodstick »
Helped a fellow member install master cylinder and brake lines...
ken462
Post by ken462 »
Fabricated and welded in a patch panel to replace the rust that was acting like the front of my bed.
WrongBedDave
Post by WrongBedDave »
Chased down a rattle in the driver side door today. Looks like the felt on the anti-rattlers finally wore out. Tomorrow i start on my rewire. Gonna be a bit of a chore but should be worth it.
Dave
63 Wrong Bed 2WD : 302/C4, drip rails shaved, aluminum radiator/e-fan, 16 gallon fuel cell, "custom" gauges, 1000W sound system
Photobucket Album:
http://s1084.photobucket.com/albums/j413/davewave649/
Build Thread:
viewtopic.php?f=32&t=27105
mrgoob
Post by mrgoob »
Installed a set of Per-lux 200T fog lights. Need to wire several accessories, hopefully this week.
F7BIGJOB
Post by F7BIGJOB »
Took my mirror heads off and flipped the mounts so the don't work the way in when closing the doors, spray waxxed taillamp lights and front bumper using 0000 steel wool and polishing, ....
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
William-in-St George
Installed a set of Carpenter visors, the mirror and the defroster tubes with dash covers. Mama was in a big hurry to move furniture so I had to go!
William-in-St. George
dbrady
Post by dbrady »
Installed exhaust system & front bumper, prepped and dropped 2 coats of paint on doors. Repainted bed and hood with a brighter shade of orange. A great day by and standard of measure :D
Darren
2010 F150
1967 Mustang Coupe
1966 F100
I finally decided colors.
I have been very busy this week getting my house & shop in order (need the shop in order to work on the truck).
I did manage to remove the wipers and cut off the windshield rubber though.
I worked on Iris abit too.
64crew4x4
Post by 64crew4x4 »
I started mine up after letting it sit idle for a month....Had to use it for the flat bed to move a rabbit hutch across town....
it got a fresh tank of Fuel for the hassle.....:)
Been cleaning the property up some with it too.. getting ready to dismember the Dodge and get sheet metal gone, then FINALLY make some forward progress on the Crew....:(
Stable of Trucks.....
61 3/4 ton 4x4..312v8,4speed Daily driver.
64 1/2ton C.C. 292v8,3sp,...???? 82k orig.miles
65 1/2ton flareside parts truck
64 1/2ton Flareside currently 4x4.going to be 472 powered Gasser
65 SuperCab/Crewcab Cummins 1 ton Duelly Hi-Boy Project
Uncle Skip
Post by Uncle Skip »
Looked at the freaking chips and scratches in my new paint from where I tried to mount my grill.... :evil:
Harper
Post by Harper »
Located and bought the correct shorter 302 engine perches and am currently cleaning, sanding and painting them...
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
Built a crate Loaded truck parts to bring to freight terminal so I am driving her to the dock
12649
Brians1966
Post by Brians1966 »
Day Off went for a cruise :steering: and enjoyed woohoo.gif
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
MadMaxetc
Post by MadMaxetc »
Got one side of my cab corners replaced.
My Build Thread
Gary Seymour
Post by Gary Seymour »
I did some more metal work like ken464 and MadMaxetc. I got the bed floor patch panel trimmed and fitted - pretty much ready to weld in.
Took a few pics but they didn't turn out.
Casey 65
Post by Casey 65 »
Leaned on the bedside, drank a beer and wished it was Slick Stock...
slickstysix
Post by slickstysix »
Sanded, painted, cleared, wet sanded and polished the filler hole in the cab, replaced the fuel sending unit gasket, filler tube hose and filler tube to cab gasket.
Now no gas fumes in the cab!
Degreased engine and then cleaned up all the over splatter on the windshield and cowl....
- Power brakes
- DJM drop beams
