Mystery Grommet?...
jefflovesf250s
Mystery Grommet?...
Post by jefflovesf250s »
All: Grommet below came from my now dismantled 66 F250. Any idea what this grommet is for or where on cab body it should be located? It is missing most of the flange which is 1/4" larger diameter than the tubular upper part. Whole unit has a full length split on one side so it probably surrounds a cable or fuel-line tube and then is fitted into the hole in the cab sheet metal.
I'll need a new one once I figure out where it goes on the cab and its part number & description.
Sorry for the blurry picture, hopefully someone will recognize it even from the blurry image.
Thx, Jeff
Truck grommet 004.JPG (236.16 KiB) Viewed 533 times
Truck grommet 003.JPG (223.31 KiB) Viewed 533 times
Re: Mystery Grommet?...
Jeff
it took me a while but remembered when i was digging thru my wiring stuff today, its for the windshield washer wire that goes from the switch to the pump.
