been awhile since we worked on the truck. My son really wanted to get it running so we spent the last week working on it. Motor bay finished up, gates dump out the fenders. Just waiting on a map sensor to come in and then we can put the injectors in and tune it. It runs good at light throttle though.
61 f100 Uni, P71 Vic Swap, Twin Turbo 6.0
Re: 61 f100 Uni, P71 Vic Swap, Twin Turbo 6.0
What speedometer are you using? Looks good!
Killer build!
Wow it is all business under the hood
Big M its an autometer american muscle here is a link to summit:The Big M wrote:What speedometer are you using? Looks good!
https://www.summitracing.com/int/parts/ ... /overview/
finally after messing around with tuning issues (1st time tuning an n\a car adding a turbo) its running pretty good. tires smoke pretty easy at 6psi of boost. just put the 13psi springs in it but havent ran that setup yet.
Will be ordering some valve springs asap, its getting valve float over 5k rpm
kids got it all cleaned up for the car show!
Not sure what went wrong with the truck but it randomly just decided it didnt want to run right. Let it sit for a week and made a new tune that was super rich and lowered the boost back to 6psi. Its running again with out issues just really rich. Im thinking its getting false knock with higher boost levels and cutting timing and going into limp mode.
A couple quick videos from this morning. This is 6psi and super rich, afr gauge sits at 10.0 under load (max low).
quick rip/ spool up:
https://www.youtube.com/watch?v=Q0RT4Qy ... e=youtu.be
burnout:
https://www.youtube.com/watch?v=HQqopip ... e=youtu.be
burnout:
Man that thing is crazy under the hood! hahahaha looks like a war machine
Any idea what kind of power it's putting down?
I havent dyno'd it, but its running about 10-12psi, would think around 550rwhp. quick clip from the other day, Didnt want to get the neighbors mad.
https://www.youtube.com/watch?v=WVnRxBchN1A
