Unibody decode
jercasche
Unibody decode
Post by jercasche »
I was out looking at someone's collection and found two unibody trucks.
I tried to look up the door tag but can not find anything.
f10yk851729. It has a 3 spd on the floor and a y block.
1964 F-100 SWB, 292,
IC front suspension
No-Limit Fatbar 4 link
full rewire complete
T-5 transmission
Front Tilt Hood
Re: Unibody decode
I'm having a little trouble with that one:
F10= 2wd half ton (F100) Y= 743 c.i. Cummins, not likely to be found in a uni; and 851729 is waaay too high a production number to be assigned to a uni! This info is direct from Autolite parts manuals and Ford repair manuals; so there should be some degree of accuracy between both "official" sources.
Going forward to 1966, s/n 851729 would be a 352- engined F100 made in Kansas City in April 1966, but certainly should not be a unibody, nor a y-block!
Sounds kinda like a case of incorrect door tag, which in the case of a uni, would be the first clue, since the early unis did not have a door tag. Do you know if the door is in fact the uni design (straight horizontal crease below belt line)?
jercasche
Re: Unibody decode
Post by jercasche »
It appears that someone replaced the tag or the door. It is a uni for sure. It will not let me post pics.
IC front suspension
T-5 transmission
Front Tilt Hood
Re: Unibody decode
Post by Gritsngumbo »
For photos, using the attachment feature on this site is "iffy" at its best. Try uploading pics to something like Photobucket and then dropping the IMG (or IMG thumb) code into your post/comment.
Re: Unibody decode
Post by rickairmedic »
The door tag on the uni is definitely wrong as there were no door tags on Uni's . Look on the inside of the glovebox door for another tag as that's where the tag would have been on a Uni.
Re: Unibody decode
rickairmedic wrote:The door tag on the uni is definitely wrong as there were no door tags on Uni's . Look on the inside of the glovebox door for another tag as that's where the tag would have been on a Uni. Rick
Have to call you on that one Rick. The 61 and AFAIK the 62 had the glove box warranty tags and the 63's had door tags. (I have both a 61 and a 63 Uni).
Pretty sure that the warranty tag placement wasn't Uni specific.
rbeck204
Re: Unibody decode
Post by rbeck204 »
Agree with grits.
I also believe the Y in the code was the plant the truck was built, not the engine. LMC catalog has a few pages that help decipher the codes.
61 T Bird Convertible
1953 Ford Customline 2 door
Re: Unibody decode
Grits is correct as stated earlier. Pretty sure it's going to be a '66 door. If the glovebox data plate is present, please post and we will decipher the original equipment.
Richard, all sources I know of list as follows:
Fourth digit is engine, fifth is plant. http://home.earthlink.net/~threynolds2/ ... s6166.html
Three Ford service manuals and one Autolite parts catalog also agree. I'm not aware of any "Y" truck plant back in those days.
F7BIGJOB
Re: Unibody decode
Post by F7BIGJOB »
Per vinwiz :1966:
http://www.vinwiz.com/1961-1980fordtruc ... 10YK851729
:oops:Sorry Paul, just re read your post, same info scared.gif
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
jercasche
Re: Unibody decode
Post by jercasche »
I will have to check in about 2 weeks when I go back.
IC front suspension
T-5 transmission
Front Tilt Hood
